Administrator
Administrator
Staff member
MTC
Fords
Great photos and notes posted by @enigman
Why I bought it
  • I wanted a retractable bed cover and Ford didn't offer one
  • I wanted the option to still add bed rails, which is a specific feature of the XR model
Things you should know
  • You lose almost a foot of space that the canister takes up, but that's only at the top of the bed, you have full access underneath it
  • The XR model's clamps restrict the movement of the in bed rail system, this is specific to the XR because of extra support needed to support a load on top, the MX doesn't have this issue
  • The canister has drain hoses that are about half an inch in diameter, you'll need to drill into your bed to accommodate them,
Installation
I have no experience with trucks and am just moderately handy and I was able to install this in about an hour without much issue.
Final thoughts
If you need the ability to add a bed rack on top of your cover and don't mind losing a bit of space in exchange, then I'd recommend it. It works for my use case, but wont for everyone.
Product Page
Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics & feedback 2022 Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics 7
Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics & feedback 2022 Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics 6
Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics & feedback 2022 Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics 5
Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics & feedback 2022 Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics 1
Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics & feedback 2022 Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics 3
Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics & feedback 2022 Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics 2
Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics & feedback 2022 Ford Maverick RetraxONE XR retractable aftermarket bed cover installed pics 4
James St. Patrick
MARYLAND
2022 FORD MAVERICK Velocity Blue Ecoboost AWD
That is a great looking cover, but the price is steep!
Enderet
Did you buy it directly from the manufacturer or who did you buy it from?
Also, how long did it take to get to you? I called Retrax and RollnLock and they both said 4-5 weeks.
BDennis
Bruce
So Cal
What is the depth into the bed? Thx
FortyFiveNorthoods
PNW
2022 Ford Maverick Lariat FX4 4K
Looks great and is what we're planning. Is there enough room to fit sheets of plywood below the canister and above the wheel wells?
onetequilatwo
Massachusetts
2022 Hybrid Lariat Maverick and 2019 RAV4
Looks great but too much $$$'s for me 1,449
SpacemanSpiff
Tyreese
Mid-west
F-15 Eagle
The Roll-N-Lock is similar, but it uses a compact proprietary hinge design for the aluminum slats and its take-up box may use less space in the front of the bed?
Their application notes for the Maverick: "OE cargo management tracks will be utilized or removed & discarded for installation of Roll-N-Lock(R) unit. Impedes use of OE accessories."
Theosud
Ted
www.linkedin.com
2022 Ford Maverick Hybrid
@ Administrator,
Thanks for posting this info as I've been looking for a retractable cover that will allow installation of bed rails. Please share info and pix once your bed rails are also installed. Thanks!
RTR_Ford
Would be sweet if they made a clamp that tied into the accessory rail.
Suzukiridr14
Frank
Sarasota Florida
Before you drill holes in your truck bed, I watched a video where someone installing a fold up bed cover, showed where there were rubber plugs below the rails at both fwd, and aft ends of the bed where drain lines (about 1/2") were connected to the fwd section of the bed cover to drain water from the rails the cover sits on.
FortyFiveNorthoods
PNW
I think this is the one you're talking about.
Mikeysd
Michael
San Diego
Maverick Laiat pepper red Lux package 2022
I love to get one for mine.
