2M Ham Radio Interference
csuh13
Castro Valley, CA
Maverick XL
I finally got around to installing my 2M mobile rig in my Maverick. It works fine, but every time I key up to transmit my Android Auto connection disconnects and disappears, and will only reconnect after I unplug and reconnect my USB cable.
Anyone have any ideas on what I can/should shield in the Maverick to prevent this?
Jeff D.
Jeff
Duluth, MN.
Mike, I don't have any tips on adding shielding to prevent interference, but I do have a funny story on the havoc 2 meter caused me in my semi truck years ago.
I had an early all band Icom 706, a fairly large 2 meter linear (i think it was around 300watt), and a pair of stack square loop antenna's. I mostly talked sideband 2 meter.
When I would transmit, the energy transmitted from the antenna's would turn on all the fluorescent lights in my sleeper. Would drive me nuts driving at night.
I don't know if it's still part of the reg's, but back then you were suposed to fill out a form that reported how much energy your station was exposed to.
IIRC, 2 meters is one of the worst frequencies for tissue heating, similiar to a microwave oven. When I did my calculations, the distance between my head and the antenna's, the antenna's gain, and the power output of my linear, it was marginal on safety. Luckily I didn't transmit that much. I was more of a listener.
Had the duty cycle been alot higher, maybe I'd have another hand growing out the side of my head by now. :wink:
Anyways, good luck on figuring out a work around for the Android Auto. :)
NJBob
New Jersey
It may sound counter intuitive but maybe try a wireless dongle for android auto. And make sure there isn't a voltage drop when you key the Mike.
Matso
2011 Mustang GT Premium
Is it possible a high VSWR could cause such interference? Worth a check although you've probably done that.
Cherokee
Marty
2026 Ford Maverick Tremor
A capacitor ?
Like in the big amp stereo’s?
Holds up the power sag on key up ?
wax87
Stuart
Dallas South
2004 Avalon
I wonder if you turned off fluorescent lights of neighboring rigs, Humm????
