25 Lobo Start/Stop Eliminator Install Thwarted?
Luminvent
2025 Ford Maverick Lobo
Today I was in the process of installing a start stop eliminator on my 2025 Maverick Lobo, and I was following the instructions and got to the step where I remove the metal bracket covering the plug. I tried putting a 7 mm socket back there, but it seems that perhaps Ford from the factory crushed the hex head and now I can't remove the bracket to unplug the connector. Is this something that anyone else has experienced? I've provided a picture of the backside where the head of the bolt is located.
Ford Maverick 25 Lobo Start/Stop Eliminator Install Thwarted? 20260621_144245
RodLS
Lobo
From 4Dtechs website.
  • PLEASE NOTE: Ford has started replacing he 7mm screw with a security screw in some vehicles. If this is the case, simply use your fingers to bend the metal connector cover out of the way.
It takes a bit of force but just bend it out of the way.
GA Hot Pepper
Dick
Georgia
Mustang Mach E, F-150 Lariat, Toyota 4 Runner
If you want to defeat Auto Start Top. Just plug in a trailer light checker in the 4 pin connector. Start stop doesn’t work when trailer is connected.
Ford Maverick 25 Lobo Start/Stop Eliminator Install Thwarted? IMG_3620
mwelby
mwelby
New Mexico
2025 Ford Maverick 2.0
Yes. Same issue. I returned it to Amazon for a full refund.
bluelobo26
Nick
San Francisco
2026 Ford Maverick Lobo
On my 2026 Lobo, I did have to bend that metal cover out of the way to plug in the eliminator, then bent the cover back to its normal position. Works fine and I really like not having to punch the button every time I start.
Regarding the no start, check the factory plug very carefully for bent pins. Something likely got misaligned in the truck-side connector since it won't start even when put back to normal.
I have heard that this plug will disable the BLIS system.
Luminvent
Luminvent
The pins look all right to me. It makes the little chirps and whirrs when I try to start it and the airbag lights illuminate but the dash screens don't come on and the engine doesn't start.
I also tried disconnecting the negative battery terminal and leaving it to reset the computers, but that still didn't work.
Ford Maverick 25 Lobo Start/Stop Eliminator Install Thwarted? 20260622_134252
