25 Lobo Start/Stop Eliminator Install Thwarted?
Luminvent
2025 Ford Maverick Lobo
Today I was in the process of installing a start stop eliminator on my 2025 Maverick Lobo, and I was following the instructions and got to the step where I remove the metal bracket covering the plug. I tried putting a 7 mm socket back there, but it seems that perhaps Ford from the factory crushed the hex head and now I can't remove the bracket to unplug the connector. Is this something that anyone else has experienced? I've provided a picture of the backside where the head of the bolt is located.
Ford Maverick 25 Lobo Start/Stop Eliminator Install Thwarted? 20260621_144245
RodLS
Lobo
From 4Dtechs website.
  • PLEASE NOTE: Ford has started replacing he 7mm screw with a security screw in some vehicles. If this is the case, simply use your fingers to bend the metal connector cover out of the way.
It takes a bit of force but just bend it out of the way.
GA Hot Pepper
Dick
Georgia
Mustang Mach E, F-150 Lariat, Toyota 4 Runner
If you want to defeat Auto Start Top. Just plug in a trailer light checker in the 4 pin connector. Start stop doesn’t work when trailer is connected.
Ford Maverick 25 Lobo Start/Stop Eliminator Install Thwarted? IMG_3620
Luminvent
Luminvent
And now my truck won't start, even if I put it back to normal... 🤬
mwelby
mwelby
New Mexico
2025 Ford Maverick 2.0
Yes. Same issue. I returned it to Amazon for a full refund.
