2025 XL Tie Down Holes in Bed
hamm107
Shaun
Maine
2009 Honda CRV
I picked up an XL last week. I could have sworn that the holes in the bed up near the cab for a tie down D-ring looked like they were threaded, and maybe even the ones up on the side. I was searching here to see what size bolts and rings people were ordering and it looks like I need to get a tap because the holes aren't threaded, but now I can't tell because I already got Line-X sprayed in. Although this definitely seems true for older models, an anyone confirm with a 2025 XL that the holes are not threaded? I guess even if they are, I might need a tap just to get the Line-X out of there.
Tim d
Alpena
Ram
They are threaded on my 23 xlt.
Doccus
AL
2025 Ford Maverick Hybrid XL
My 25 XL was threaded. I have the factory SIBL. The taps clean threads making it easier to use but I have put bolts in some without using a tap first. The above link is spot on as to sizes. I have used them all, installing a front molle panel and two side rails.
hamm107
Shaun
Maine
2009 Honda CRV
Okay so it sounds like unlike previous years, the 2025 XL has threaded holes. If I didn't get a spray in liner in the holes, I wouldn't have to tap, but with the hole full of LineX, I'll probably have to. Maybe I'll try threading in an M8 bolt first before I buy a tap to use once.
hamm107
Shaun
Maine
2009 Honda CRV
I did read that thread that a couple of you posted before I posted the question... it is what made me realize that my holes might not be threaded. I'll get a tap as recommended to clean the liner out of the holes, since a $10 tap is worth more than the hassle of a sheared off bolt or mangled threads.
It does sound like the 2025 XLs come with threaded holes based on a comment above. So no tapping necessary if you're not not getting it sprayed, or if you plug the holes prior to getting a sprayed in liner. Haven't seen a picture of a naked 2025XL bed with threaded holes yet though to confirm that. Definitely seems like all prior years they were not threaded, based on other threads.
canuckford
Lou
toronto ontario canada
2025 2.0L ECO, 2015 Transit T250
I wouldn't use a tap just yet, try a wire brush attachment for a drill and spin that in there, I don't know if it will work, but it's a less aggressive option then use the tap if you must.
