2024 Maverick Small Transmission leak Hybrid
Domainman
Austin
Northern California
Ford C Max Energi
This is the general FYI for everybody who has somebody else do your maintenance. I was changing my oil on my 2024 Maverick with 8800 miles on it and found an oil like substance on the transmission. I also reviewed the under body cover and found there has been a drip on that as well. I have done two other oil changes went at 750 miles and one at 3500 miles and there was no signs of this during those changes. It appears to be transmission fluid. Planning on taking to a dealer soon
Ford Maverick 2024 Maverick Small Transmission leak Hybrid IMG_0856
Ford Maverick 2024 Maverick Small Transmission leak Hybrid IMG_0857
Ford Maverick 2024 Maverick Small Transmission leak Hybrid IMG_0863
Peter Lukasch
Peter
Vancouver Island BC Canada
1987 GMC S15 4x4
It almost doesn't look red enough to be transmission fluid. I'd double check and make sure that is actually trans oil and not engine oil coming from somewhere above. .
23grayXLT84
Midwest
23 hybrid xlt
Its transmission fluid 100% and its a somewhat know issue. You have to consider two things 1) undercover masks the problem and 2) most people utilize dealer etc for oil changes. This is likely ignored....meaning that a lot more trucks have the problem .
The fix unfortunately requires the engine to come out. They can't simply tighten the bolts without creating more issues.
I'll add this. I suspect most techs dont even notice it or wipe it down and send the car on its way.
Warranty work pay sucks from what I heard and no one wants to mess with such a big job just to fix a leak.
TATANKA01
ROBERT
YUMA, AZ
2023 MAVERICK LARIAT
My 23 Hybrid is weeping fluid too and when the warranty expires I’ll be weeping too!
BlueSpec1
Gene
Domainman
Austin
Northern California
Ford C Max Energi
Bill K
William
Maine
2023 Maverick
All vehicles weep fluids. Our Maverick’s are no exception.
FreedomPenguin
Dayton
my Toyota with 220k miles literally has no fluid leaks, engine is bone dry, trans is shiny chrome.
actually blows my mind. I was just under it a few days ago as I did an oil change on a lift and checked it all out.
meanwhile my gf's chevy sonic had 60k miles, and everything on bottom of engine was leaking and covered in crud and oil / fluids.
Bill K
William
Maine
2023 Maverick
I’ve long followed the philosophy that if there are no weeps, then you are out of fluids.
This doesn’t include dripping, excessive leaks.
Domainman
Austin
Northern California
Ford C Max Energi
It’s just an FYI do with the information what you’d like.
Peter Lukasch
Peter
1987 GMC S15 4x4
One leak was from cooling lines to the transmission:
https://www.mavericktruckclub.com/f...il-leak-at-67k-miles-update.32268/post-661563
Inspect the transmission fluid cooler tube assembly backing rings and seals for damage and install new backing rings or seals if necessary.
1. Backing ring (7J324)
2. Seal (7D258)
Thanks for this post, makes perfect sense, looks like a fairly simple repair for a DIY.
2. Seal (7D258)
Good to know, in case I notice any weeping this is where I'll look first. thank you.
Elderchuck
Curt
Minnesota
2025 Ford Maverick Lariat
In past experience dealers claim a threshold before a leak is considered worth addressing, small drips or even a wet case does not typically meet their standard. I had one repair center tell me to wait until I have a puddle on my garage floor (likely after warranty).
Domainman
Austin
Northern California
Ford C Max Energi
Update 1
I took my truck into the dealership today and they reviewed the leak while performing a recall. They cleaned off the fluid and put a dye in the transmission drove it 10 miles and the leak came back. They noted that the truck went drove in was about 1 quart low on fluid. They believe that one of the seals was improperly installed during manufacturing at the bell housing. They noted that they have seen this before and it is going to be a 22 hour job including an engine removal to correct it.
