2024 Lariat Tremor HPR
Cancunbadlands
Cancunbadlands
Cancun
Cancun
I'm in the market for Mod 18
Exhaust!
Any recommendations?!
Nothing fancy just a plugged in aftermarket Exhaust to make some nice deeper noise
Magnaflow or Borla or... ?!
I'm a cheap retired pal
I just wanna replace the factory one
‘uses a sophisticated twin-clutch rear drive unit (similar to the one in the Focus RS or Bronco Sport Badlands).’
Not sophisticated enough for a 4K tow rating eh ?
Wow. That surprised me. Off road work I would think would be harder on a RDU than towing 4k
BigClydeLittleTruck
Clyde
So I've continued to read and research on this idea and it seems to make some sense that the decreased towing limit on the Tremor is actually due to a combination of factors rather than just the difference in the RDU alone. Things like the factory lift, softer suspension, differences in the cooling, the simulated locking rear diff, etc. all seem to align in a way that adds up to a lower payload and towing capacity.
Cancunbadlands
Cancunbadlands
Cancun
Cancun
The short answer is that the Maverick Tremor lacks the specific heavy-duty cooling and gearing hardware found in the "4K Tow Package," and its specialized off-road suspension is too soft to safely manage the tongue weight and stability requirements of a 4,000-pound trailer.
While the Tremor has the same 2.0L EcoBoost engine as the trucks that can tow 4,000 lbs, it is fundamentally optimized for trail riding rather than heavy hauling.
Cancunbadlands
Cancunbadlands
Cancun
Cancun
Towing 4,000 lbs puts immense heat stress on a vehicle’s powertrain. The Maverick’s 4K Tow Package adds several critical cooling components that the Tremor does not have:
Upgraded Radiator
Upgraded Cooling Fans
Transmission Oil Cooler
Differing Gearing
Soft Off-Road Suspension
Aerodynamics and Packaging
@bigcitydelittletruck
@Cherokee
Cancunbadlands
Cancunbadlands
Cancun
Cancun
Exhaust!
No downpipe or fancy stuff
Chops
Lobo
I'm in the market for Mod 17
Exhaust!
You’re going to face a challenge, CCBL. Magnaflow does not offer a complete catback - and even their standalone mufflers won’t work. Your OEM muffler has the the hanger connector welded on to it. Any standalone aftermarket muffler won’t. This is the underside of your 24 Tremor:
Ford Maverick 2024 Lariat Tremor HPR IMG_0216
Ford Maverick 2024 Lariat Tremor HPR IMG_0217
Borla does make a complete catback for your Tremor I think $800 - but those of us who bought one say “ouch - too loud!!” unless you spend $100s more modifying it.
Forum Sponsor MRT may have something to fit your Tremor - but will it sound what you’re looking for?
Good luck on your quest!!
Cancunbadlands
Cancunbadlands
Cancun
Cancun
Alright, I got a better perception now, TY pal, so it's not plug and play
Cancunbadlands
Cancunbadlands
Cancun
Cancun
The hanger connector can be welded on by a pro shop, right?
Cancunbadlands
Cancunbadlands
Cancun
Cancun
They really should be standard on at least the Tremor. Looks so much better!
Here...
The wheel fender flares is standard for the Tremor Package in South America
Cancunbadlands
Cancunbadlands
Cancun
Cancun
Cancunbadlands
Cancunbadlands
Cancun
Cancun
What about the Borla Pro-XS 40358
Would it fit? Sound?
Cancunbadlands
Cancunbadlands
Cancun
Cancun
Well looks like the
Mod #18
Is here!
Some cheap Chinese lug nuts ABS caps
Time will tell, they feel kinda "loose"
Not tight enough
Ford Maverick 2024 Lariat Tremor HPR 20260117_173756
Ford Maverick 2024 Lariat Tremor HPR 20260117_174854
Ford Maverick 2024 Lariat Tremor HPR 20260117_175734
