2022 maverick shaking
Dallasfan1
William
Burlington nc
22 ford maverick
At about 6000 miles I took my maverick to dealership and they had to wait on ford to tell them what to do about the shaking ford finally told them to replace my axles so the did both axles got it back drove fine for about 4000 miles and last week it started to do the shaking again took it back to dealer and now waiting for ford to tell them what to do next has anyone had this happen to them
Deleted member 1483
Guest
Yes, my truck shakes on mid-hard acceleration. I am pending getting the axels replaced. Replacing the transmission mount didn't fix it.
Not happy (as the reason I replaced my escape was the engine stuttering when I merged on highways, and this problem has the same effect to make it difficult to merge), but that's what a warranty is for. Truck is flawless otherwise.
Dallasfan1
William
Burlington nc
22 ford maverick
Yes it is a great truck if they would just figure out what is going on with it like I said before already had both axles replaced so I don't know why it just started shaking again just waiting on ford to get. Ack to me for the solution
GPSMan
Many
Axles? Seems a weird conclusion.
What about the engine to transmission "damper"?
Nomav
Stephen
NC
2021 FJG Mach 1 HP
Motor mounts?
Dallasfan1
William
Burlington nc
22 ford maverick
Went back to ford today they told me ford told them to put 2 more axles in my truck I hope this fixes the problem seems like every 6000 miles it starts to shake real bad if it does it again there is more wrong then the axles
skyhawk
Airplanes motorcycles cars SUVs
wow. Ask them what they find wrong with the axles when they remove them this time, if they are able to immediately tell - like has the grease leaked out? That would be evident because there would be grease everywhere.
Torn/cracked boots would also be easy for a basic tech to see.
Dallasfan1
William
Burlington nc
22 ford maverick
I will ask them thank you I actually got under the truck myself and looked I haven't seen any grease or fluid leaks it's just weird that it keeps doing it around every 6000 miles
tycorc585
RC
Rochester,NY
None
Hey man curious on how your truck is doing. Mine just started after 15k thought it was tires. You’re the 2nd person I’ve read that’s had multiple run ins with this. I love this truck too hope ford does something cuz not gonna be fun after warranty. :(
