2.5 block design?
fremont
NorCal
2011 Fusion Hybrid 2023 Maverick XL Hybrid
I was wondering if anyone has a picture of Mavericks engine block with the head off. I would like to know if its closed deck or open deck block design. I know my older fusion hybrid 2.5 has a closed deck design so would like to know just out of curiosity.
I don't remember but has been posted earlier. Search for open or closed 2.5 deck.
EngineeredDetails
Andy
Vance, AL
2004 F150, 2016 Fusion, 2017 Explorer
It's going to be a closed deck design since it's a low power output engine. The open deck blocks are usually going to be boosted engines that need the extra cooling around the cylinder walls.
GPSMan
Many
Is this detailed enough?
Ford Maverick 2.5 block design? IMG_8579
Ford Maverick 2.5 block design? IMG_8581
GPSMan
Many
How sure are you about that?
Internet says the opposite.
Low Horsepower & Naturally Aspirated is most often open. Better cooling, but cheaper to make and weaker design.
Semi-closed and closed: much stronger design, can tolerate turbo boosted engines, much more expensive to manufacture, run hotter but are designed for it.
🤷🏻‍♂️ I'm not an expert. Just reading about it since someone brought it up.
RedRider
Kitchener, Ontario, Canada
Its the same engine, with some small modifications only.
fremont
fremont
NorCal
thanks guys appreciate the help, engine design looks like a winner to me.
