Mikesb
Western North Carolina
2022 Ford Maverick FWD 2.0 EB
My 22 ecoboost maverick. 2.3 swap in January, after #3 went low on compression. Check thay thing out in the pics! Guess it got a lil 🔥! I spent bonus money on a snow stage 2 meth injection setup, some stance SR10 rims and a matte metallic green wrap. I did the wrap myself, along with all the rest. Everyone want a dyno sheet, but I dont have one. I need a good on dyno tune to really open the 2.3 and take advantage of the methanol cooling, i need to crank up the timing. Ihave a livernoris tune currently, and they replied that they could, but that's in Michigan......
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims IMG_20250523_150529
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250525_165725
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250522_171928
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250519_203520
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250521_121332
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250503_105633
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250522_080345
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250418_154343
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250522_165857
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250525_082323
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250119_090210
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250119_090233
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250526_071123
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250503_081922
Ford Maverick 2.3 engine swap, methanol injection, wrap and new rims 20250418_133755
that piston ring land is pretty jacked, ouch. what did the other pistons look like?
Big Swede
Challenger
The ring gap is probably too tight from the factory and the rings expanded and took a chunk of piston with them.
matmondro
Mathieu
Vassar, MI
Just looked at your other thread too... wow! Great work! The 2.0 Mav is already quite peppy, so I'm sure this 2.3 feels awesome. Very interested to see the numbers once you can get some more tuning done!
at the mileage he listed (100k+) something is going to eventually fail especially on a tuned engine used at high rpm. apparently it's the ring land. I see some damage to the top of the piston but it doesn't look melted so it's probably the pieces of the piston and ring that got smashed into the valves and piston top.
I'm curious to see all the valves also, if he took pics.
Grant C
Grant
Your wheels are fire. What size are they? Where did you buy the
Connect
JD
Tx
2013 Honda Accord, 2023 Maverick XLT Hybrid
Really like the color and wheels. I'm going to need to replace the factory tires probably by the end of this year... I usually do a wheel swap when I replace the factory tires but have been having a hard time finding some I really liked. Time will tell I guess... but your combo is pretty nice
Big Swede
Challenger
It’s toasted for sure. It looks like a big section of piston chunked off above and below the ring which usually means the rings got heated up and expanded pushing against each other with no where to go. That ends up putting tremendous pressure on the piston and will break a chunk off.
It usually just chunks the top of the piston off because the lower half of the piston has a bunch more metal to push away from the rings. In this case it looks like the lower part of the piston got pushed away from the rings expanding as well since there’s not a lot of piston material above the lower ring and below the upper ring. Above the oil control ring as well. Pretty wicked.
ring land failure is a common issue on turbocharged engines that are modified, especially those that use cast pistons and/or short skirts, which are also common on modern engines because of the mpg benefits. this piston has a decent skirt, but I bet it's cast given the maverick's low cost and low factory horsepower.
when fuel and timing is good, but the load is high, eventually this is going to happen. there was nothing for the OP to have done differently, unlike if we saw a melted piston, rod bearing failure, etc.
Big Swede
Challenger
For sure. It’s very common on cars not build for forced induction and then someone throws a supercharger on it. The ring gap is set for NA for mileage and emissions and when it gets too hot pop goes the piston. Hemi 392’s are known for it.
Snox801
Levi
Spring Lake Michigan
Looks like an oil issue to me. Things do happen but the tune looked good based on that piston. But a lots of bad things can happen in the rings when oil fails. But parts fail and it may have just been a weak link in one flawed piston
Snox801
Levi
Man I can say it would be worth the trip to lms. They did my last two with meth injections and both went crazy high mileage before they were replaced
