2.0 EcoBoost engine -- overall feedback?
Chase300
Atlanta
2024 Maverick XLT
The AC in the hybrid starts cooling almost immediately too. Much faster than my other gas only vehicles...which is very nice here in Atlanta during the summer.
colinl
Colin
ICT
cooling faster? nah, ecoboost works extremely well, also.
what you're really feeling is that Ford is very serious about strong heating and air, both. the HVAC in every late-model Ford I've been in is extremely robust, even if the car has been sitting in 100+ degree sun, or frozen in -15 degree winter.
the hybrid can keep the AC compressor spinning when the engine is off, but of course it can, the internal combustion engine is often off.
dochawk
doc
Las Vegas
No fix yet for CV axles
A Dodge?
[ouch. oof. {bleed}.]
OK, never mind.
Anyway, I'll extend my observations from test-driving the 2.0 a couple of days ago: *far* more power than I ever expected out of a 4-banger--and that was without the turbo, whose whine-up I heard as I was lifting my foot off the pedal, having given up on there being any more.
Chase300
Atlanta
2024 Maverick XLT
More so the electric AC compressor can spin up faster.
" Since the electric compressor speed is not tied to engine speed, it can provide maximum performance at any engine speed, unlike the belt-driven compressor. The capacity can be controlled to match the cooling demand, providing optimum comfort while maintaining energy efficiency. "
Another plus for the Hybrid.
colinl
Colin
ICT
interesting and I wonder who wrote that?
I was under the assumption that a modern HVAC system could hit max compressor speed with the engine at idle. it will be a higher % of drag vs engine output, true, but considering it's idling I doubt that any drag on engine output is a real concern for fuel efficiency.
it definitely matches the cooling demand with the compressor clutch.
Chase300
Atlanta
2024 Maverick XLT
This guy;
Erik Huyghe is the Director of Advanced Engineering for T/CCI Manufacturing, a world leader in compressor technology including electric, reciprocating, swash plate, wobble plate and variable compressor designs.
Snox801
Levi
Spring Lake Michigan
I’m actually shocked they don’t do this on the ice engines anyway. Much like power steering the alternators are good enough now to produce the power. Would also help increase fuel efficiency just like electric power steering.
Superg0
2024 XLT FX4 Azure Gray
Just checking in on this thread 👀
Joshua
Wisconsin
2024 Ford Maverick XLT AWD
To cure the auto stop start, I just push the button to turn it off right after starting the engine each time, that way it’s stays off and I don’t curse
I do the same as you - turn it off. Wish Ford reversed that option where it always off and if you wanted to engage it and use it then you hit the button. I don't always remember to turn it off as soon as I start the truck...
shark978
texas
canyon
I will just say, the 2.0 is very peppy and will get you up to speed quickly. And if you’re not happy with normal mode, push the button and select sport mode and hold on. I think you’ll be surprised. It won’t match the 5.0 mustangs I’ve had but it’s not suppose to.
Had zero issues with mine, do your maintenance well, oil/filter change every 5k, full synthetic oil and tier 1 gas brands, think you will be pleased. That’s my experience
5k isn't nearly often enough. Oil is cheap a new engine isn't. 3k miles would the absolute max i would go. but ideally 2k or less. dont be lazy.
