12VDC power available under hood?
PapaRed
Will
Glendale, AZ
2023 Lariat Hybrid, 2002 Saturn L200
In preparing my '23 Lariat Hybrid for recreational vehicle towing (flat towing) I need a source of 12 VDC under the hood with ignition off. Normally I would wire directly from the battery, but that would require a long run since the battery is located under the rear seat.
A source of 12 VDC power (with ignition or accessory off) under the hood would simplify things.
Donald
Donald
Morehead City
2023 Ford Maverick XL
i used the battery jumper post for my brake controller and charge line. I also installed a 12 volt lighter plug under the dash for my RVi brake controller. Towed 2000 miles round trip to Key West and back. No problems.
Ford Maverick 12VDC power available under hood? 82D80A9C-7CC7-4024-8A13-D8623E0922FC
Ford Maverick 12VDC power available under hood? 93184194-5CAB-4C4C-BB64-726E44FAB25D
Ford Maverick 12VDC power available under hood? 2070C254-2A03-4E72-A222-40C83A06AF17
PapaRed
Will
Glendale, AZ
Good idea! What brake system are you using? I'm using the M&G system towing with an Itasca Meridian motorhome - had used M&G on 2 earlier vehicles, but the Maverick needed the M&G 2.0 system.
Would be interested in your experience towing the Maveric.
Donald
Donald
Morehead City
I’m using the Portable RVi system. Very easy set up and can move back and forth from our Honda CRv. The Maverick towing set up was very easy.
Vicky
2023 XLT Ecoboost Area 51
Do when you flat tow, do you put the truck in neutral?
rivermaverick
Fort Mohave AZ
Don't connect anything directly to the 12V battery - doing so bypasses the Battery Monitoring Sensor and confuses the system.
PapaRed
Will
Glendale, AZ
So, John - If I do not connect to the battery, where would you suggest? My auxiliary brake system requires 12 VDC to operate correctly when towing the Maverick behind the motorhome. It was recommended to use the battery jumper post.
SLINGSHOT
Charles
NE Iowa
2017 RAV4
Don't have a truck yet, but from reading the manual, I would guess the positive and negative battery jumper posts under the hood.
Also where you would hook up a battery tender or a jump box.
Right, guys?
Palms
Gus
Jensen Beach, FL
21 Mercedes GLC; 23 Maverick Hybrid Lariat
I took a triple tap in fuse 24 (spare) to my mounted 12v female socket and shared ground for my BlueOx Patriot. Separate switched and constant taps for Valentine One G2 and dash cam with separate rear cam (powered by same cable to main one). Under hood post positive for RVi battery maintainer and front led bar, negative to one of the chassis grounds right under positive post. Hope it helps.
