12 volt question
M Spec
South Carolina
1978 Toyo LC, 1988 911, 2005 STI, 2010 STI, 3 More
I have a question regarding the 12 volt power source in the bed of the Maverick. I am aware the Ford supplies a pigtail plug for the bed 12 volt harness. The question is, " If I want to install a 12volt LED flood light on the back of my truck do I need to use a relay or is the supplied 12 volt already configured relay wise and therefore none is required?"
Thanks for any assistance.
FYI, I plan on using a single Nilight 4" LED flood/spot combo (30watts, I think)
M Spec
M Spec
South Carolina
No knowledge anyone?
Big_T
T
2022 Maverick XL Hybrid
I don't believe there is a relay, it's a simple 12 volt source. The plugs in the bed are marked 15 Amps but the owners manual shows one 20 amp fuse supplying both plugs in the bed.
Spook
Central KY
Maverick Lariat Hybrid
Other than a switch to keep your battery from running down or light burning out, you are good to go.
M Spec
M Spec
South Carolina
Thanks guys for the the input! So my take away is switch on one side, direct wire to bed 12 volt, no other issues.
M Spec
M Spec
South Carolina
One other question I forgot to ask... Is the bed 12 volt ignition switched or not. My presumption from Spook's post is that it is not switched. ?????
Big_T
T
Power remains at the connector for a period of time after the ignition is switched off....I can't remember if it's 15 minutes or 30, but it does turn off.
M Spec
M Spec
South Carolina
Hummm, Interesting..... Thanks guys for the replies.
HD676
Patrick
PA
2018 Harley, 2007 Shelby GT
15 minutes.
HD676
Patrick
PA
No. You must turn the key back on to have power again.
