Hey guys, compiled a clean, all-in-one breakdown of the fluid specs, capacities, and official part numbers for the Maverick platforms (2.0L EcoBoost and 2.5L Hybrid) to make sourcing your next service kit easier. I got everything through Rock Auto. Also Summit Racing has the Valvoline ULV and Red Line 75W-85.
EDIT: Just updated the main list. Realized I completely forgot to list the AMSOIL ULV and the 75W-85 PTU fluids in the original write-up.
1. 2.0L EcoBoost (8-Speed Automatic — 8F35)Note: There is a widespread shortage of all ULV Transmission fluid. I went with the Valvoline Full Synthetic ULV.
- Transmission Model: Ford 8F35 (Includes Lobo 7-Speed setup)
- Required Fluid Spec: MERCON® ULV (Ultra Low Viscosity)
- Total Capacity: ~11.6 Quarts (Higher on models equipped with the auxiliary transmission cooler like the FX4, Tremor, and Lobo).
- DIY Drain & Fill Capacity: 4.0 to 4.5 Quarts (A standard drain plug service only drains what is in the pan, leaving the rest trapped inside the torque converter).
Fluid Pump- W1139
Trans Fill Funnel- W4034 18" Funnel
- Motorcraft 1-Quart: XT-12-QULV
- Motorcraft 5-Quart: XT-12-5QULV
- Valvoline Full Synthetic ULV 1-Qt: 888460
- AMSOIL Signature Series ULV 1 -Qt: ULVPK-EA
If you drive an AWD or Tremor/Lobo EcoBoost/Hybrid model, you also have a front Power Transfer Unit (PTU) and a Rear Drive Unit (RDU) to service.
- Required Fluid Spec: SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant (Ford Spec: WSS-M2C942-A)
- Capacity: ~0.5 to 0.7 Quarts (Buy 1 Quart)
- Motorcraft Part Number: XY-75W85-QL
- Red Line Synthetic -75W-85 -Part Number :50104
- AMSOIL SEVERE GEAR - 75W-85 - Part Number : SVLPK-EA
- Required Fluid Spec: SAE 75W Disconnect Rear Drive Unit Fluid
- Capacity: ~0.8 to 0.9 Quarts (Buy 1 Quart)
- Motorcraft Part Number: XY-75W-QL
- Transmission Model: Ford HF45- HF55 eCVT
- Total / Service Capacity: 4.5 to 5.5 Quarts (Note: Because the HF45-HF55 eCVT is an electric transaxle case without a torque converter, a standard drain plug drop empties almost the entire unit's fluid capacity).
- AMSOIL Signature Series ULV 1-Qt: ULVPK-EA
Both the EcoBoost (8F35) and the Hybrid (HF45-HF55) use MERCON® ULV. Do NOT use older MERCON® LV (Low Viscosity) fluid, as it is thicker and can cause mechanical issues in systems built strictly for ULV formulations.
I contacted Valvoline tech support directly to confirm compatibility for a drain-and-fill on my 2024 Tremor’s 8F35 transmission. They explicitly confirmed that Valvoline ULV Full Synthetic ATF is engineered and 100% safe to use in applications requiring the Ford MERCON® ULV spec. If you want a premium synthetic alternative to Motorcraft that’s easy to source or bundle on Rock Auto and Summit Racing you are completely good to go!
