How much does it cost to get the transmission, PTU, and RDU fluid changed?
Morerecalls
Oklahkma
2024 Maverick XL
I’m thinking about letting my go to repair shop do the maintenance at 1500 miles then every year in October.
What do you think?
Ksprelude01
Keith
St louis. Mo
2022 Ford Maverick Lariat FX4
That's my plan to do it yearly. I just did mine a couple weeks ago while doing my oil change. I think it was $140 just for fluids to change the trans, PTU, and RDU. It took me a little over an hour to do. Just do it while doing an oil change since you have the bottom cover off anyways.
Richard2212
Richard
Indiana
2020 Fusion , 1984 Mustang
That is how I do mine. Less than $200. at home. Engine/Filter,Trans,PTU,RA - I do it once a year @ about 5000 miles
Morerecalls
Morerecalls
Oklahkma
2024 Maverick XL
Do you just refill the transmission fluid by 4.25 quarts? How do I level it? I don't think I am able to take the leveling plug off.
Richard2212
Richard
Indiana
Measure the quantity you drain - put that much in.
The Level Plug is accessible after removing Driver side Wheel and Tire. The plug is a 5/16" or 3/8" Allen Hex or equal Metric. Be sure car is back to level when checking level.
tciotti2003
Tony
Arizona
2022 Lariat
Bought my 2022 EB 1st edition Lariat last Feburary with 21k miles. Within 2 weeks I took it to my local service center and had all the fluids changed including the PTU RDU. Even had them drain the windshield washer fluid and change it out to new ( that was a freebie) Was right around $789.00 out the door. I also asked to see the PTU RDU fluid which they provided. The reason I did this was because I read a thread posted here about the metal break in contamination in the RDU PTU. And there was some metal shavings but not like what was shown in that post I referred to
Ksprelude01
Keith
St louis. Mo
I over filled it 4.75 quarts. Drove it around for 15 min, i think my Torque app said the trans was 180F when i came back to check the fluid. Turn the wheels to the left and you can reach the fill level plug. I use the pump that I used for the PTU and RDU to pump a little extra fluid into the trans till a good flow was coming out of the hole and screwed the plug back in after the flow got to a trickle.
Morerecalls
Morerecalls
Oklahkma
2024 Maverick XL
Was it a dealership or an independent shop?
bgn
WA
The transmission fluid on the EcoBoost should be drained between 185 and 200 Fahrenheit. I'd be fine with 180, but just throwing it out there for other folks that are yet to change theirs.
Gpp
Gil
Sanford nc
2022 ford maverick
Ok,maybe I missed something but why are you all changing all the fluids so often?
tciotti2003
Tony
Arizona
2022 Lariat
I did it for 2 reasons. 1st I read a post on this forum regarding the metal shavings in the RDU PTU fluid that came off the line and now I set the benchmark knowing all is set it 21k
jb_cb900
Dallas
2024 Ford Maverick
I understand "checking" your trans fluid level at those temps, but why do you say it needs to be 180° to drain it?
bgn
WA
I should have been more clear in what I said. I don't think temp matters much in the initial drain, but it does for when the leveling plug is opened.
