Michigan WTB OEM Moveable Tie-Down Cleats
kingranchero
Dearborn
www.ford.com
2023 Ford Maverick Tremor
Looking to snag 2x of the moveable cleats if anyone is selling
Ford Maverick WTB OEM Moveable Tie-Down Cleats 1666706890512
RobA979
Rob
Snook, TX
Ford Sport Trac
Any luck finding any - I have been looking. Even went to Ford but they could not find it in their parts.
kingranchero
kingranchero
Dearborn
www.ford.com
Nope nope. Surely they exist in the world, there have been totaled Mavericks with the CMS/Tie-Down option, but I have had no luck on eBay or anywhere else. I will try talking to my dealership parts department to see if they can help.
The engineering part number is NZ6J-E27740-A, and the part itself is marked with "24388 CAV7", but these do not turn up any results. The CMS Tie-Down kit mentions that "A kit to add (2) extra cleats is available as an accessory", so you would think these exist somewhere!
Don806
Don
SE Ohio
noticed this today while looking around on the ford accessories site
Ford Maverick WTB OEM Moveable Tie-Down Cleats 1671042547722
Fastbackjon
Jon
Iowa
2022 Maverick XLT 2.0, 18 Flex, 20 Edge, 21 Escape
FYI---- Ford Accessories emailed me on Jan 20th 2023 and said the cleat kit is back in stock. NZ6ZZ6000A64A. I ordered a set as I believe having 4 cleats is better then 2.....
GadgetDad
Jeff
Toledo Ohio
22 Maverick - Alto Blue FX4 4k Tow Lariat Lux 360
Did these come in and worked for what you were hoping? Looking to do the same.
Fastbackjon
Jon
Iowa
Yes- they arrived a couple of days after ordering. I am installing them when the weather warms up around here. They are identical to what came with the truck. (I did take a couple of the existing rail fasteners loose to make sure it would be an easy job.) Just make sure you have the proper bit for removing the rail from the bed quarter. I found it works best with a 3/8 socket driven torx bit. The rails are quite torqued to the bed quarter.
GadgetDad
Jeff
Toledo Ohio
Perfect thank you. I tried looking at victory ford accessories and googling the part number and didn't see it. Will try calling the local dealer next for them.
Fastbackjon
Jon
Iowa
Go to the Factory Ford Accessories site, search under Maverick and there should be a cleat kit listed.
GadgetDad
Jeff
Toledo Ohio
Varsity ford up in Ann Arbor had it on their web site for $84 so just snagged them :) Thank you again for the direction. Also picked up the divider kit for my existing cleats - they had that down below 240 vs 310.
vcpayne
Van
Richmond, VA
Maverick (on order)
Hey-- I'm not having any luck find those two items on the Varsity site. Could you share links?
GadgetDad
Jeff
Toledo Ohio
