Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
So after seeing how everyone was mounting their @WOLFBOX cameras, I decided I had a few thoughts. 1. I wanted mine in the car. I don't really hear about people stealing these things much, but the less temptation the better. Additionally, it would protect it from the elements which can't be a bad thing. 2. I wanted it as high as I could get it and centered. My psuedo-OCD wouldn't like anything off center as it would show in the rear view cam and I wouldn't be able to NOT notice it all the time. High as possible is just about being able to get the best view of what's happening behind me. 3. I needed to figure out a way to handle the sliding 5th window. Many don't have this option, but I do and it means I can't just mount it to the window itself.
Enter frivolous spending and 3d printer purchases!! I have a little experience in 3d modeling and have prototyped all sorts of stupid things since my ownership and decided it was a perfect solution. I printed an adapter that the camera can attach to with the "2 arm" mounting option to give myself a little space and flexibility. It pulls the camera away from the window to avoid hitting it on opening, has a small channel for the cable to be routed through to clean and direct it, and it has a little ledge on the bottom to match the level to the window trim support piece.
It certainly could use a few version updates (I can think of 2 right off the top of my mind), but it'll do the job for now for sure. I've yet to see what happens with any kind of glare/reflection due to the lense being away from the window a little allowing light bleed, but I didn't notice it during prototype 1 so I think it's probably fine. It sticks out a little more than I'd like but realistically, no one's head is going to hit that in the middle.
If anyone has some suggestions or wants the stl files or even wants me to print/send them one, let me know and I'll see what we can work out. Lots of things suck in this world, but gotta love the DIY-ability of things these days!
EDIT: 3D Files can be found at: https://thangs.com/designer/Wilklersticks/3d-model/1357779
There are a few thicknesses. The thicker you go, the more adjustability you will have but could introduce reflections. The thinner you go, the less adjustability you have, but you run a better chance of no reflections. Maybe use double-sided tape to see which you like best.
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20250605_000152247
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20250605_000157485
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20250605_000202467
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20250605_000134028
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20250605_001840914
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20250605_001916058
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20250605_002113089
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20250605_001928536
Slisher
Tennessee
2023 Ford Maverick Tremor
This is great! I've been holding off on purchasing the Wolfbox, because I wanted to mount the rear camera over the back window, but wasn't sure the best way to do that (OCD is fun, if you let it be).
How does the mount attach to the railing on top of the back window? Does it rest on top of the railing, and the cable run holds it tight against the rear panel?
Would you mind sharing the STL file?
Wilklersticks
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
The mounting tape that comes with the wolfbox camera works pretty well. I destroyed it over the course of prototyping so this happens to be 3m "30 lb." double sided tape. I used a different double sided tape in another iteration but it had too much play and caused the camera to shake, which is obviously annoying. The tape is applied to the back of the adapter and then the front of the rail. I wanted to try add a clipping mechanism to hold onto the rail, but there's no real room in the back against the wall to full wrap around, so we're stuck with mounting tape.
Regarding the cable run, I didn't have a picture of it, but you can tuck the cable up into the ceiling padding and around to the side and then go a few directions. I ended up going down and behind the seat, but I'm thinking of going up and around along the top instead. Haven't really landed on a final decision.
I hadn't uploaded the STL anywhere yet, but I probably could/should. Otherwise if you want to just dm me your email, I could just do that.
Tuch
Pa
With this new option to install in the cab that you created, I'll most likely now purchase. Just going to wait until you post the STL first. Thanks for sharing.
Steamboat
Boston, MA
2025 Ford Maverick
Looks awesome! Im waiting to pick my new Maverick up from the dealer next week and have my Wolfbox ready for install.
I’ll send you a DM to see if you’d be willing to mail me an adapter.
Wilklersticks
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
For those wanting the STL, I made a couple revisions tonight that I really want to test out tomorrow, so let me install it and then I'll hook you all up.
Toddman45
St. Louis, MO
That's pretty fucking impressive kudos to you for creating that little bracket. It would drive my OCD nuts to have the rear camera mounted to the right or left side of the back window.
I have my camera mounted dead center of the rear window but unfortunately for me I don't have a power slider one thing I miss for my full size f-150s, as well as the rear defrost which I don't even think is available on the Maverick..
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window PXL_20240906_053221704
WOLFBOX
Diamond Sponsor
Florent
2024 Maverick XLT
That's really a great idea! Thanks for sharing with us :beer:
Is that a G930? Could you please share more pics?:love:
TwuckHappens
Jefe
2025 Maverick Lariat
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window 1749349772277-cj
Just using the included mounting bracket
Wilklersticks
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
Snagtooth
Ohio
2024 Lariat
I used what was provided in combination with another bracket on Amazon. I considered printing one too but prefer the adjustability this allows with fine tuning the camera angle. Cost was minimal too.
Ford Maverick Wolfbox (or maybe any) rear view camera - 3D print mount avoiding the rear 5th sliding window IMG_3127
