Wiring through cubby?
Overdraft
Murlin, USA
2023 Ford Maverick Hybrid
I'm sure that someone has asked this in the past but I'm far too lazy to browse. Is there a way to run a cable through any possible ports in the cubby hole? I as you can see I ride with my scanner on the dashboard I don't want another cable hanging down just curious if there's a way through feed the power cord through the cubby down into the center console thanks buds
JfredTrem
Justin
Maryland
23 Maverick XLT Tremor
the console/dash is VERY ease to remove.... the climate controls just pop out as a large panel with the vents.. and the top tray does the same. I am very sure with those out of the way, you should be able to get a cord through to the usb plugs on the bottom.
do you want us to do the work for you also?
bgn
WA
You can drill the bottom right of the cubby and route the cable to where you need to. I would take off the glovebox and poke around to see what works for you.
Yeah if you don't mind. No way in hell I trust myself to do all that
Good Luck, I'm sure there are auto shops, electronics shops, etc that you could pay to take care of it then
BlueSpec1
Gene
MTC: Wiring 12v power to the Dashboard Cubby, and Center Dash Removal -- DIY how-to video
