Wiring diagram for stereo connections?
Harry_Haller
Ariel
Buenos Aires - Argentina
Maverick Lariat
Forum,
Does anyone have the wiring diagram for the connection of the stereo of the maverick?.
The idea is to get a full range signal and from what I could see that signal is taken from the rear.
My idea is to clamp from the main unit and analyze all the signals with an rta and decide later.
If someone has the connection diagram, it would be appreciated.
Slds.
HH.
uh50
Howard
www.hchaney.com
2022 Maverick XL, VB, 2.0 EB
I've been looking for an XL actual wiring diagrams since November but have not found one. I have some pin connection diagrams from a similar ACM in 2017-2021 Fiesta and Focus if you are interested. Just let me know and I'll post it again.
I had planned to see if the pins matched my XL, but never got around-to-it. :cool:
The Speaker Guy
2022 A51 Lariat Lux CP360 SIBL Hybrid
If you have BnO system the link to the amp is A2B, which does have some aftermarket support.
uh50
Howard
www.hchaney.com
From shop wiring diagram
The following in diagram from a 2018-2022 Ford Focus appears to match your shop diagram noted PIN numbers on the ACM. Obviously I don't know about pins 16, 17, 27, and 28.
Ford Maverick Wiring diagram for stereo connections? Ford Focus (2018-2022) ACM non-SYNC external display Head Unit pinout diagram @ pinoutguid
The following is a 6 speaker system wiring diagram and the PIN numbers match the pinout guide above.
Ford Maverick Wiring diagram for stereo connections? 6 Speaker System
Jwhisl
Tulsa
2014 f150
Doe
Ford Focus (2018-2022) ACM non-SYNC external display Head Unit pinout diagram @ pinoutguide.jpg
Great info! Does your info show what connector b is for?
uh50
Howard
www.hchaney.com
Doe
Unfortunately no, but only the "A" connector is used on my XL. Here is a photo that shows "B" empty on my XL. The red circle high-lites the "A" connector.
Ford Maverick Wiring diagram for stereo connections? 1661020745334
Recently, 07_Shelby posted 11 updated diagrams linked here: #8. And three shots directly from the manual linked here: #16. Thanks to 07_Shelby.
Here is the link for the complete thread: What is the correct wire to splice into for remote in audio harness?
Even with that info, it doesn't tell me the use for connector A. Sorry.
Jwhisl
Tulsa
2014 f150
I was just curious. Thanks
BoxxerDad@50
Kip
Lees Summit MO
MY25 XLT BAP XLT HYBRID SOLD MY 2023 XLT hybrid 2023 Lariat,MY22XLT
In this diagram for the rear which is the ground and the power pink/yellow brown/white not able to figure this out? Also did the rear speakers help sound overall? Not planning a AMP but have already upgraded the front speakers.
