Wireless charger overheating?
thedm96
Atlanta
2024 Ford Maverick Lariat
I have a Galaxy S23 and when I use the wireless charger the phone gets very hot and doesn't seem to charge much.
I've had to use a plug-in charger. Am I the only one experiencing this?
It seems like the cubby needs ventilation
huunvubu
coppell tx
2023 Ford Maverick Hybrid
Wireless charging results in heat being generating as there is no way for power to be transmitted without loss. That loss generates heat.
Disadvantages of Wireless Charging Technologies
Productivity Issues
Wireless charging systems generally have lower efficiency rates compared to wired charging systems. Losses during energy transfer can make the charging process slower and energy consumption higher.
Heating Issues
During wireless charging, the device and the charging unit may overheat. This can both shorten the life of the device and pose potential risks to user safety.
CurtisB
2023 Maverick XLT Hybrid
The wireless system in the Maverick is of average quality. And if you are using Carplay or Android Auto while driving and charging it will definitely get really hot.
Jeff D.
Duluth, MN.
Tim, I have a Pixel 8a. I had it on the wireless charger the other day, while driving, and was also using wireless Android Auto for navigation, and it did get rather warm. It was just over an hour.
I believe it only charged 4% in that time, also. I think it was drawing almost as much as it was charging.
I didn't notice anything else amiss, though. It didn't hang up or act glitchy atleast. :)
Deleted member 15125
Guest
I have the same problem changing my iPhone SE!
thedm96
Atlanta
Yes I am using Wireless AA which turns on both the WIFi and Blietooth antenna. The phone gets toasty hot. If ford adds wireless AA they are going to have to address better phone cooling during the summer. Perhaps redirect some of the air to the charging area.
PRH
Robert
Canada, Ontario
I've found 2 things, if I'm using my M1A motorola adapter with my S23, wireless charging can't quite keep up. Not terrible if I start a journey at 100% battery charge but if I'm at 30... I'm gunna be dead (or close) by the time I drive 500 km. Secondly, I put a divider in and use an independent wireless charger ... just a high quality one.
Matso
2011 Mustang GT Premium
Yep it's basically useless. So let's remove one of the most functional exterior features on a vehicle which is the keypad and replace it with what is basically a hotplate in the console. Now if it heated up my ham sandwich while on the road I would say great! But alas it only serves to draw who knows what multitude of amps while baking the internals of my phone. The pet rock earns higher points for ingenuity.
Matso
Oh and I forgot to mention as you already know, any protective case must be removed for wireless current to transfer. What a PITA.
One bonus is fuse position 18 in the BCM panel (7.5 A) looks like an attractive tap site for the ACC when hardwiring a dashcam. Since I'm never going to use the hotplate again, why not?
Oscarcat
Eric
Encinitas California
Me: iPhone 8 - on the Ford pad, it charges but slowly in the Otterbox case, gets warm but not hot. To speed up the process I don't use any apps while charging. My wife's iPhone 14 almost always needs to be charged and it is conveniet for her to just set her phone on the pad. My '22 Lariat didn't have it [no lux pkg] and I didn't miss it.
Exranger
Northern California
Yes it heats up the phone. My friends phone got very hot. It was a newer iPhone
Mako316
Mansfield, PA
2024 Maverick xlt x4 4k
Yep, same problem with Pixel 7. I think I'm going to attach it to the a/c vent instead of the cubby mount.
fossil
ernie
ohio
I can see slow charging as being the pads problem but how is a phone getting hot the pads fault? Seems like if the pad put out more power the phone would get even hotter.
Jeff D.
Duluth, MN.
I use an "SP Connect" mount/phone case, which raises much of the phone slightly off the charger, but it still seems to charge ok? It does get warm(hot?) but it's hard to quantify if it's too hot?
It does have a metal ring that matches up with SP Connect's wireless charger for motorcycles, so maybe that helps transfer energy here, too?
Only using the phone for navigation and not music, it does go postive in charge rather than negative over time. Very very slowly, though.
Ford Maverick Wireless charger overheating? PXL_20240609_181827434
thedm96
Atlanta
It can be mitigated by directing cool air into that area or making the layer between the charging coil and phone out of a thinner material so there isn't as much energy loss to heat.
