Window Rain Guard Issue
GduB
Garl
NY
2022 Ford Maverick XLT
So I have rain guards that came with the truck from factory brand new in 2022. I’m not sure what the brand is. Can anyone help explain why it’s not properly deflecting water around the window? It never bothered me too much before but I recently drove through a very buggy area and was constantly using the wiper fluid, which sprayed me with a considerable amount of fluid through the 1in gap of the open window.
When the window is shut, wiper fluid and rain will still spray the window. If the window is cracked even the slightest, liquid will literally pull around the bottom edge and trail up the backside of the guard and spray into the window while driving.
I’ve never had this issue with any other vehicle that had rain guards. Design defect in this brand or was this one just installed wrong?
Ford Maverick Window Rain Guard Issue IMG_9983
REMUB40
Fredericksburg, VA
2018 Honda CRV
I have the factory ones with no issues. I only crack the windows halfway down the deflector. Yours is at the very bottom
Al Czervik
Pete
Myrtle Beach
2026 Maverick Lariat 2.0
I went with Weathertech in channel rain guards on the back windows only. This way I can keep the truck vented in the heat but I don’t have to deal with them up front. Same strategy I used for the previous 13 years on my scab F150.
GduB
GduB
Garl
NY
If you’re referring to the picture I attached, the window isn’t cracked at all. It is rolled all the way up in the photo to show that the deflector sprays fluid even with the window up.
baccus100176
SC
26 Lariat Hybrid AWD
Wow that’s interesting. I’ve had Weathertech guards on all my vehicles and never had this issue. Not familiar with the Ford brand rain guards but are they installed in channel vs surface mount?
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
I think they’re Lund brand, mine are set onto the rubber which is lower and fits the mirror better and never had problem with windows being cracked open for venting. But if yours are onto the painted surface maybe 🤷‍♂️
Ford Maverick Window Rain Guard Issue IMG_3973
scott1070
Scott
calgary
25 lariat
Pro tip:
If you keep the window closed when it’s raining, you won’t get rain inside
GduB
GduB
Garl
NY
I’ve never had it either, it does seem to only be my driver door one that sprays the window like that. They are surface mounted which is what I suspected might be the problem, but only on one of them? I looked at it this morning and the front portion near the mirror is tucked into part of the trim which creates a gap in the trim, could be part of the problem.
GduB
GduB
Garl
NY
Do you by chance have a picture of where the rain guard meets the trim near the mirror? I thought mine were mounted correctly until I saw where they tucked the front lip of the rain guard behind the corner trim near the mirror, it does create a gap in the trim which now I think might be part of the problem.
GduB
GduB
Garl
NY
Do yours look anything like this?
Ford Maverick Window Rain Guard Issue IMG_0111
Ford Maverick Window Rain Guard Issue IMG_0110
Ford Maverick Window Rain Guard Issue IMG_0109
Ford Maverick Window Rain Guard Issue IMG_0108
ShadowChas
Chuck
No yours are mounted on the painted portions and is why the gap is by the mirror, mine are mounted on the rubber seal itself (I used the instructions provided) and I like the looks & they were also the only ones available the first year. Here’s a photo directly off Ford parts showing a white vehicle better to see than my black = note the smooth transition from the mirror actually lowers the placement
Ford Maverick Window Rain Guard Issue IMG_7519
GduB
GduB
Garl
NY
Leave it to Ford to install their own accessories wrong from the factory 🤦🏻‍♂️
Can’t even follow their own instructions lol
Garl,
They were probably in the backseat of the truck and installed at the dealership by the lot jockey.
