Will these wheels fit
2cafn8d
Monica
Huntington Beach CA
2022 Maverick XLT
What size were you planning on getting? They do offer the correct bolt pattern. This is a website that I love to go to that gives me a visual on things and numbers. You will need to input your current setup and then input the new. Don't do hub spacers if you can help it. Find a wheel with the right bolt pattern and a good offset. (I just received my Sparco Terra wheels. 18x8 +35)
https://www.wheel-size.com/calc/
TacoHolder
Phoenix AZ
Not Mav
Yes. The only size that will fit is 17x7 in 5x108. 18" doesn't have the correct bolt pattern and the others are too small to clear the brakes. You don't need spacers with +38 offset. It's the same as stock.
ttheroux
Hamden. CT
2022 Maverick AWD
Thanks, by spacers I meant bore spacers to center the wheel on the hub. I would be going with the standard 17” wheel size.
Brett3550
Brett
WI
Velocity Blue XL
Lariats have 18" rims. Why do you think 18's wouldn't fit? There are a few guys on the forum running 18" rims.
TooManyVehicles
Upstate NY
15 F150 XLT, 21 BS Badlands, 22 Mav Hybrid
He is saying the 18 inch version of this wheel ( vision boost) doesn’t have the 5x108 bolt pattern.
2cafn8d
Monica
Huntington Beach CA
2022 Maverick XLT
Just to help you on your searches. They are called hub centric rings.
stewpac15
Springfield MO
do you happen to have any pics of those sparco terras mounted...?
2cafn8d
Monica
Huntington Beach CA
2022 Maverick XLT
Unfortunately no. The scheduling gods still don't think my June order is worth scheduling yet. So it will be quite some time before I see it in my driveway.
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
Those are similar to the ford factory OEM 18” focus wheels
Ford Maverick Will these wheels fit 8767C615-A460-4F4B-A0C2-C108007661C5
ttheroux
Hamden. CT
2022 Maverick AWD
I scored these Bronco Sport wheels
Ford Maverick Will these wheels fit 6E83B389-99AD-4CC1-AD2D-3DD668DA4A9C
off facebook today! $200 with the lug nuts. They will look so much better than the steelies.
I scored these Bronco Sport wheels off facebook today! $200 with the lug nuts. They will look so much better than the steelies.
FYI the Bronco Sport lug nuts are too small (12mm) for the Maverick (14mm).
ttheroux
Hamden. CT
2022 Maverick AWD
Well that is unfortunate and kind of surprising given that it’s the same platform.
