Will 16" wheels + 235/70 tires clear?
phobiarg
Alex
Southern Maryland
2022 Ford Maverick XL 2.0 AWD
Im not a big fan of big wheels and low pro tires. Every car I've owned with them end up with bent wheels, a side wall buldge and/or an overall uncomfortable ride on anything but the smoothest roads. I plan to buy a set of wheels and tires for my XL and am strongly considering going with 16s with 235/70R16s so long as they'll fit. So with all of that said, does anyone know if 16s are even an option?
Me also, 70's much better choice of tires with durability.
kingranchero
Dearborn
www.ford.com
2023 Ford Maverick Tremor
Yep! Just make sure you find 16" wheels with similar dimensions to the existing wheels - 7 in width, 37.5 mm offset.
TSAINTS1115
Thinking the same on picking up a set of winter tires/wheels as the 16" are cheaper.
Finnster
N. E. Wisconsin
Any updates on this thread?
Will 16" wheels clear on the Maverick? How about 15's?
Randy_270
Randy
Manitoba
I got some 16” steelies from my focus in my shed, it might not be this weekend but next, I’ll try them on my Maverick.
es7129
Ed
Long Island
I tried a set of 16x7.5 +42 wheels and the inner diameter of the barrel didn’t clear the front caliper. Some 16s will work but I would test fit before committing money to the set.
Seems like someone posted one that would fit but when I looked them up they were only rated for 900 or 1000 lb load. So we're sheet metal
Randy_270
Randy
Manitoba
Finally got to trying the 16” steelies in my shed, I didn’t buy them new so I’m not sure of the offset, all I could find is that they are 16x6. From the looks of the rims, they are very positive, maybe +50ish.
Here is some photos of how tight the clearance is.
Ford Maverick Will 16" wheels + 235/70 tires clear? 811440DD-9D3F-4294-A4A8-4CD0162F81EE
Ford Maverick Will 16" wheels + 235/70 tires clear? EB33F9D0-6F86-4D76-B7FD-BB819C34AF01
Finnster
N. E. Wisconsin
Wow, That looks tight!
Are going to run them to see if they touch at all? Might want to stay off of gravel roads.
Randy_270
Randy
Manitoba
Unfortunately, they are too tight for my comfort. Gonna have to sell them and put the money towards some 17” steelies…
Bluebaru
N/A
Virginia
Bronco Sport Badlands
You may want to try them with a 6mm spacer to see if you then have enough room. Steel wheels being much thinner than allows, with the spacers, should be no problem, maybe even an 8mm.
