Where’s the (VSS) Vehicle Security System Module on Lariat located w Pics
cjames138
DFW
2022 Maverick XL Hybrid
You do not need that fob to turn in the car, you can use the factory key. See the video
As I said before, the antenna extends the range of the one button fob. It won't affect the original fob in any way.
4sambos
4sambos
Kevin
Peru, IL.
Camry Hybrid,
Go to your OBD port, behind it, are there 2 sets of cables, one leading somewhere and another to a black box?
Hi mine has no black box (perimeter alarm box) so per yours and other suggestions I need to buy the perimeter alarm box to plug my antenna into. Since I already have the factory remote start added on my Maverick I won’t install the pigtail jumper. Thank you everyone for all your help. The Ford instructions were vague to say for me to plug into the VSS (vehicle security system module) which I looked very hard for and did not see it. Again thank you much
Skyline
Skyline
CT
'24 Honda Ridgeline
Ford states, quote:
Your Ford may be equipped with a remote start system that allows you to turn on the ignition from up to 300 feet away.
Source...
One would say that your remote should be able to start the engine upto 300 feet away with your FOB. Unless the OEM FOB does not have the range and Ford want's you to buy another remote, that has a 1,000 feet range:
https://accessories.ford.com/products/remote-start-system-long-range-w-confirmation-key-fob
Mine did not have the OEM remote start and installed the VSS box instead. It does support the OEM FOB to start the engine remotely via the "Lock-Open-Lock" combo. The range is about 30 - 50 feet that could be increased with the range extender antenna. Other than it needs to install the antenna around the windshield or near glass, it would had require purchasing an extended range FOB for the remote start. Since I didn't need the extended range, I didn't get the extended range FOB.
Hardening2753
Ford Maverick Hybrid
Good luck brother
4sambos
4sambos
Kevin
Peru, IL.
Camry Hybrid,
From what I am seeing the Maverick does not use a VSS, the security system is incorporated in to the BCM(body control module). What part number is this antenna you have and who sold it to you? I am thinking it may be an antenna that is used for the dealer installed add-on remote start systems. If you can message me the part number( and your vin would help too) I will look it up when I am at work(dealership) for you tomorrow.
Hello, need your help in after installed I tried to follow your link to enable the VSS with horn honks, etc.. But my 23 Mav Lariat has a pushbutton start and not a key? What am I doing wrong since I tried adjusting the sensitivity button and banging hard on steering wheel as per instructions but no alarms? TIA lots
Senior Master Ford Guy
99 Ranger, 04 and 18 Escape, 2023 Maverick Lariat
Do you have the actual programming instructions or just the install instructions? I'm not sure exactly what you need.... there is a specific procedure for turning on the alarm system, and programming the fobs to it(you did get at least 1 separate fob with it didn't you?
4sambos
4sambos
Kevin
Peru, IL.
Camry Hybrid,
Do you have the actual programming instructions or just the install instructions? I'm not sure exactly what you need.... there is a specific procedure for turning on the alarm system, and programming the fobs to it(you did get at least 1 separate fob with it didn't you?h
Mike, I only bought this VSS box to hookup my extended range remote start antenna I was sold thinking I only needed the antenna? So I bought it, hooked it up then tried the procedure to test it after hookup but no good. Now I’m stuck, and I wish I’d never bought antenna and went w VSS box after all this trouble. Had I know I needed more than antenna I’d quit the whole thing but I don’t give up unless you tell me it won’t work. Thank you,
Okay, let's (try to) start with getting the remote start function working and disregard the security system part of it for now. I might be asking redundant(stupid) questions here, but did you see a little looped black wire that came with the VSS "black box'? and did you plug it in to the black box?
Gullzway
OK
1968 Ford Mustang Fastback
Page 8 here " VSS Module - Optional Vehicle Security Features"
2023_RMST_Common_I-sheet_9-15-22_FINAL.pdf (fordservicecontent.com)
" VSS Module - Optional Vehicle Security Features 18. Start with ignition key OFF, doors unlocked and VSS system DISARMED. 19. Place shifter in the PARK position (remaining in PARK). 20. Open driver door (remaining open throughout). 21. Depress and hold the brake pedal. 22.
NOTE: Brake pedal application is only required during the first ignition ON then OFF cycle.
Cycle ignition key ON then OFF 5 times, then back to the ON position a 6th time. Keep ignition key in the ON position for the remainder of the program cycle. NOTE: The horn will sound 3 times. 23. Close the driver door. 24. Open the driver door. 25. Close the driver door. The vehicle's horn will sound 1 time to indicate the security enable/disable option has been accessed. 26. Applying and releasing the brake pedal will toggle the security feature on/off. • The horn will sound once to indicate the security feature is ON. • The horn will sound twice to indicate the security feature is OFF. 27. Cycle ignition key to the OFF position to exit security enable mode. "
Horn should honk ONCE to indicate VSS enabled.
4sambos
4sambos
Kevin
Peru, IL.
Camry Hybrid,
i Ordered remote start for my Lariat. Only reason I needed or wanted this extended remote antenna is where I work has very limited weak cell signal to use FordPass or key fob to reach truck from wrk building to remote start it in winters. So I only bought VSS box to be able to plug in antenna to get more longer range. Now after box is hooked up I’m using the Ford VSS Installation manual to “learn the box” to my vehicle section. Hope this details help you to help me. TIA
4sambos
4sambos
Kevin
Peru, IL.
Camry Hybrid,
Gullzway, if I don’t have ignition key, so I tried the same procedure with the pushbuttonstart as instructed with no effects? So w PB is instructions same? TIA
Gullzway
OK
Yes, pushing the Start button without the brake pushed is the same as turning on the ignition.
4sambos
4sambos
Kevin
Peru, IL.
Camry Hybrid,
Ok thanks I’ll try again 👍
Your key fobs will need to be programmed to the black box also, that is why I asked if you have any fobs that came with the box( they are also listed on the accessory page there are 2 types, one way and bi-directional which sends you back a signal(light blinks) to let you know vehicle started) I personally have never attempted to program the factory key fob( which came with your truck) to one of these but I believe someone else on here commented that it can be done, so here are the directions for a pushbutton start :
Ford Maverick Where’s the (VSS) Vehicle Security System Module on Lariat located w Pics 1690331895774
4sambos
4sambos
Kevin
Peru, IL.
Camry Hybrid,
Awesome help Thanks very much all working now
