What is the difference between sport mode and the L button?
SuperK401
Kent
S. Ind
89 f-150 custom 03 f-250 super duty fx4
I have a 24 xlt 4K fx4 eco boost. I do not have sport mode. I have the L button. I live in an area where the country roads are hilly and curvy. 30-45 mile a mile an hour . There are times I love using the L button. I also enjoy having the lower gears. what is the actual difference between sport mode and the L button?
F150 2.7 TT user
Kenneth
SE WI
2026 Maverick Tremor, 2017 F150 XL 2.7
I have a Tremor with Sport and that is dependent on RPM for up-shifting. The L option by the manual holds the shifting to low gears for tight turns and hilly terrain. At least that is how I understand the manuals description.
Hot Runr Guy
West Chicago, IL
On my '24 Lariat Tremor, I found using the L button pretty much locked the trans in 3rd gear, as indicated on my ScanGauge3.
HRG
F150 2.7 TT user
Kenneth
SE WI
Still learning on our 2026 Tremor but it has changed far as modes. No L, rather the button in the shift dial is M for manual shifting with the paddle shifters. Sport mode will hold a gear till a higher RPM range before shifting up along with increasing the throttle tip in.
Ford Maverick What is the difference between sport mode and the L button? 20260721_171334[1]
Kent, @SuperK401,
You can add Sport Mode to your 2024 via FORScan.
Maybe we'll get a reply🙏
It's in that other thread for adding sport mode...super easy. Just need to use easy mode and enable the drive modes that show as disabled.
@crbalch
I was wondering. What would the link be for the "other" thread?
Could you please post the link.
F150 2.7 TT user
Kenneth
SE WI
I use the button marked M often, handy during the break-in. Have not noticed anyone collapsing and going stiff so far!
BillHanna
Cana, Virginia
2024 Maverick XLT, 2020 RAV4, 1975 Corvette Stingray
We live at the bottom of Fancy Gap Mountain, so in most vehicles I hold it in a gear or two lower. But on the Maverick EB, the only choice is "L" which in my mind shifts to way to low a gear -- I often have to press the go pedal to maintain speed. Why did they take away the ability to choose which gear we are in like on our RAV4?
I just did my XL4 Lariat for Eco and Sport modes. I didn't but could've enabled Rock/Crawl and Baja too. Don't need a bunch of choices for city driving. If I go off roading I may enable those last 2 as well.
@CroweMag55
John,
I was wondering if you could help out the folks on this thread.
Assuming they have a compliant laptop, FORScan software unit and the correct cable.
By showing the process or a link to a previous thread to enable sport mode.
Thank You.
SuperK401
Kent
S. Ind
How much does a software in the cable cost?
SuperK401
Kent
S. Ind
Software and the cable. Spellcheck.
BK007
BK007
OH
rick52
Rick
2026 Maverick
Like so many other features, Ford has really dumbed down the vehicle controls.
