WANTED: Rubber Mud Flaps
Mavster Mechanic
Hybrid
Did anyone find soft RUBBER mud flaps for their Maverick?
I do not want hard plastic mud flaps. I tried them already. They scrape on speed bumps and dips in my areas.
Looking for RUBBER (soft flexible) mud flaps only.
Thanks.
Mabett's are flexible.
Mavster Mechanic
Mavster Mechanic
Hybrid
Fits Maverick:
Well sure.... I suppose....
AI is going to ruin humanity....
Ford Maverick WANTED: Rubber Mud Flaps 1794341301498-2q
Mavster Mechanic
Mavster Mechanic
Hybrid
Rokblokz are polyurethane and plenty flexible, while being very tough at the same time.
More expensive than most.
But I was unhappy with the hard "molded" ones.
I will pony up and give these a try.
I had seen them before. Forgot the name. Thanks for suggesting.
On order now.
Case closed unless these suck too.
But these look to fit my requirement.
Tbone289
MO
On order now.
The benefit of these over soft rubber is that they aren't so flexible that they "blow back" at high speed. They're made specifically for off-roading (rallying), so should fit your needs well.
Ford Maverick WANTED: Rubber Mud Flaps 1794343174448-cz
Hot Runr Guy
West Chicago, IL
On order now.
I don't remember if you have fender flares, but if so, make yourself some spacers to fill the gap caused by the thickness of the flare.
Ford Maverick WANTED: Rubber Mud Flaps Air Design and RokBlox.spacers
HRG
