Vehicle Security System - Perimeter Plus
Lobomaniac
Central NM
2016 GT/CS 5.0 Coyote
Does anyone know if you must order this $255 option in order to get remote start with the key fob?
Or does this come standard anyway?
It seems kind of strange...
Lobomaniac
Lobomaniac
Central NM
Thanks,
I was building a Lobo 702 and it was an option...
dwbarr60
Dean
New Jersey
2026 Maverick XL
For the Security Perimeter Plus add for MY 26 , does anyone know how to get to to the Gateway Module connector ? How do you get the security bolt out or is there another way to get to it to install the T- Harness? Also where is the best place to mount the black box ? Lastly what are the Forsccan changes required to enable .? I believe the key FOB method only works with pushbutton start which is not available on XL trim.
Lobomaniac
Lobomaniac
Central NM
^ Good to know about that, but how about my original question?
Can they truck be started remotely with the fob without buying this option?
dwbarr60
Dean
New Jersey
2026 Maverick XL
As previously stated it depends on trim. Truck needs push button start and you can do it without security perimeter plus per this video -
Lobomaniac
Lobomaniac
Central NM
^ Thanks again,
So maybe the option I am seeing is a pair of new key fobs like those shown in the video, along with some security features?
Quest
Buying the fobs will not get you any new security features
But their only $30 on Ali Express, lot cheaper then the security module & easier
Lobomaniac
Lobomaniac
Central NM
Here is the 2027 option...
$255 S4
Use your factory key fobs to arm and disarm the Ford Perimeter Plus Vehicle Security System.
  • When there’s impact to the glass or a body panel, the 2-stage shock sensor determines whether to issue a warning chirp or full alarm
  • When activated by your Ford Dealer, the Basic Remote Start System is also included; start your vehicle from up to 300' away
  • LED Warning Light Kit also available – lights up when system is activated
