USB Type C No Longer Working
sgtcurry
Houston,Tx
Palisade, Model X, Ioniq 5
hah 1 year anniversary of my maverick and the front usb ports went out. The lights around the port don’t light up either.
RedRider
Kitchener, Ontario, Canada
2013 Fusion, 2023 Maverick on order
I'd bet that you in the initial stages of battery or BCM failure. Are you getting problems with the interior lights not coming on as expected?
sgtcurry
Houston,Tx
No its just the front USB port. I checked all the fuses and they all seemed good. Turned back on the car and all of a sudden it works. Ill have to see if it stays like that.
jhesse51
El Dorado Hills, CA
2024 Ford Maverick
Hi there, I'd be happy to look into your Maverick concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Hello,
I have a new 2024 Maverick XLT with intermittent USB issues. Both A and C disconnect and sometimes reconnect.
I’ve tried cables, phones, fuses, reset and factory reset. No help.
VIN 3FTTW8H94RRB59176
Dealer : Folsom Lake Ford
12755 Folsom Blvd
Folsom, CA 95630
United States
Carlitos_92
Hello,
12755 Folsom Blvd
Folsom, CA 95630
United States
Hi, just FYI that Ford account packed up and left at the beginning of the year, so they won't reply here. Depending on who you ask, they rarely offered much besides having your dealer contact you.
Jimmyland
Pennsauken, NJ
2023 Ford Maverick
Only had the truck for a few days and suddenly the type C port stopped working. It does not charge the phone or connect it in any way. There was no damage or anything pulled out it just stopped working. I have tried multiple type C to type C cables and still not working. Any idea for a solution?
The regular type A port works and I can connect my phone and charge it with no problem. Seems to be isolated to the type C port.
Update: I tested all associated fuses for the USB and they all check out. As mentioned, I believe the problem pertains to the plug assembly. I'll be contacting my dealer soon. Sucks that I've had the truck for less than a week and this problem exists.
If you want to skip a dealer trip get one of these from Amazon if used for just charging. Also lets you know battery charge status for about 8 bucks.
Ford Maverick USB Type C No Longer Working IMG_4776
jhesse51
El Dorado Hills, CA
2024 Ford Maverick
Thanks, I’ll go directly to my dealer.
wittyreply
wittyreply
Eric
Indy
Ford Maverick Lariat 2.0 Ecoboost
Thanks. I ended up taking it back to the dealership and they swapped out the right part. No problem since then, but thanks for the alternative solution.
bguen
Billy
2010 Honda Pilot, 2018 Honda Accord
Question how long and how much did it cost at the dealer.
wittyreply
wittyreply
Eric
Indy
For myself, I had the truck about 3 days from the dealership when the problem started. They replaced it for free in about 1/2 a day.
