bagman51
Southern Ontario
2017 Explorer XLT 2011 Mustang Convertible
Thanks for the video. Removing trim without damage is the hardest part. You could have cut off most of the excess tweeter wire to avoid a possible rattle? Use shrink tubing over your solder joints. Great job!
Randy H.
Randy
Bristol, CT
Maverick & Civic
Great video; thanks for the general removal information. I think I would prefer the proper wire adapters and install bezel kit for a clean install; don't care for Jerry rigging in a new truck. But, to each their own.
JohnnyBravo
D
New York
225,000 mi. Honda CRV
Does anyone have feedback on the B&O sound system offered in the Lariat? I hope I dont have to upgrade any of that.
TacoHolder
Phoenix AZ
Not Mav
General consensus of reviews say that even the standard 6 speaker system sounds pretty good. I have to assume the B&O system is even better.
HPR
Lincoln Ne
Yikes. This is where a 3D printer comes in handy. You can make your own trim rings / spacers etc. The electrical tape and lighter 🥴 .......you can get heat shrink tube WITH solder already in it, or do it the normal way. You left 2 feet of wire to slide the heat shrink tubing on. :ROFLMAO: Props for putting a video out there but a lot of techniques can be learned from soldering videos on the youtube, like twisting the wires together and pulling tight.
Headdead
Birmingham, Michigan
Boxster S
Where do you get the proper wire adapters and bezel kit of which you speak?
Randy H.
Randy
Bristol, CT
Maverick & Civic
Unless the stock wire harness and bezel are the same as another Ford they may not be available yet (odds are they are the same, just need to figure out which other vehicle(s) the Maverick got their parts from in production)
