Unused factory post on positive battery terminal?
zach57x
FL
2022 Maverick XLT
There appears to be a threaded post that is not used on the factory positive terminal clamp. I currently run 8 gauge wire directly to the post clamp but am rewiring soon with 4 gauge, could I just use that unused post and get a nut for it?
Ford Maverick Unused factory post on positive battery terminal? IMG_6126
Old Fart
Mid Florida
2022 Ford Maverick XLT; 2016 Prius ECO
Humm, one amp of 120 v AC requires 12 amps of 12 volts DC so for a 2000 watt inverter which pulls 16.6 amps you need wire for 200 amps DC or a 2/0 wire. #4 is only good for 95 amps or a 1000 watt inverter.
That's why I run a 2200 watt gas generator, when I'm in the boonies or the 2kw battery generator with 4, 195 watt solar panels.
The battery in the Maverick is pretty crappy and undersized for a large wattage inverter.
zach57x
zach57x
FL
2022 Maverick XLT
I'll be running an amplifier that outputs 600 watts
topgun/goose
earth
metro
From the American Wire Gauge Chart
AWG gaugeConductor
Diameter Inches
Conductor
Diameter mm
Conductor cross section in mm2Ohms per 1000 ft.Ohms per kmMaximum amps for chassis wiring
40.20435.1892221.10.24850.81508135
So 10 feet of #4 wire would have .002485 ohms of resistance. That means at 135 amps it would drop .335 volts from your feed voltage in a 10 foot run. So if you can get by with just 5 feet of wire to feed the inverter #4 could work just fine even at 270 amps.
Dad
Could be a tight squeeze getting your fingers/tools in that space.
MavWaiter28
Patrick
2022 Maverick hybrid
Certainly. Here's the backside, with more pics here: 2000 watt Hybrid inverter as generator
You may have to trim the red cover.
Pardon my ignorance - question for you if you're active.
Long story short, discovered my positive terminal was massively corroded, cleaned it up and replaced the battery for good measure, but I fear the positive clamp around the battery post is too loose and doesn't clasp fully anymore.
Given your photo here, can I replace just the terminal connection nearest the bottom of the image - the chunk of metal with 3 bolts, if that part is sold?
I'm far from a pro - appreciate any insight
MavWaiter28
Patrick
BlueSpec1
Gene
Unbolt cable for 12V at bottom and the small 12V feed to the BMS. Replace & bolt in new.
Ford Maverick Unused factory post on positive battery terminal? 1761367981861-9y
Ford Maverick Unused factory post on positive battery terminal? 1761396108787-6y
Cancunbadlands
Cancun
Cancun
An amplifier could work just fine tho
