Turbo replacement @ 100K miles?
Phimosis
Larry
Santa Clarita, CA
You are more likely to be replacing batteries in the Hybrids Long before a turbo in the gas version. A buddy just sold his Prius that is 6 years old for that reason.
Just because your buddy had a car with a bad battery, it doesn’t mean it is common. My first Prius developed a cracked head at 183k miles, that destroyed the engine. It was the plug in version and when the engine died, I drove it 10 miles to the dealership under battery power alone, doing 65 mph on the freeway, so the battery was just fine. I traded in my second Prius at 135k miles and the battery was fine. Now I’m in a 7 year old Tesla that has over 140k miles on it and the battery is fine. Sure the battery has degraded. It only holds 60 kWh of electricity now and it would hold 71 kWh when new, so 15.5% range loss. But it still charges and discharges as well as when it was new. Just like turbos, batteries typically last for more than 200k miles.
coppermav
2023 Maverick XLT, 2000 F-250 XLT
The turbo is far down on my list of worry items. If it fails down the road, I’ll replace it. At least I can lay on a creeper instead of laying across the top of the engine to get to the firewall where the turbo is on my 7.3 diesel.
I give warmup and cool-down time, full synthetic oil changes every 5k miles tops, and drive easy till everything is warmed up, so I don’t foresee the turbo being a problem for a long time.
  • Like
Reactions: bgn
bgn
WA
The 8F35 is more likely to need replacing before the engine/turbo, imo. The 2-liter in the Maverick seems pretty damn stout.
