Trim Tools for hiding Dash Cam Wire
nunucello
Marcello
New York
Hello MTC .... Can anyone recommend the proper type of trim tools I should use to run/hide my front dash cam wire.
Maybe something like this :
or this :
or this :
Thank you very much.
Johnkn
MD
I have the exact 2nd set. It’s all and more than you’ll ever need. Any of those are just fine.
nunucello
nunucello
Marcello
New York
Thank You √
Gullzway
OK
1968 Ford Mustang Fastback
I didn't even need tools. You can just pop them off by hand.
I've had my driver side a pillar off a half dozen times trying to find out what was rattling. Ended up being the window, fixed it when I had my windshield replaced.
Pulled the passenger side off to run my dash cam wiring.
nunucello
nunucello
Marcello
New York
Thank You. Do you have any advice for removing the side A Pillar ?
Gullzway
OK
I just pull the weather stripping back a little bit and you can grab the edge of the a pillar and just pull towards the center of the truck. Also pulling on the windshield side.
nunucello
nunucello
Marcello
New York
Thanks √
LC48
Johnson County Texas
If you want a local source the Dorman set can be picked up at Autozone or O'Reilly, they work fine and give you plenty of options
nunucello
nunucello
Marcello
New York
Thank you LC
ClemsonU88
NC
Dude, you already had your windshield replaced? Was the old one damaged, or did you get a tinted one put on?
Gullzway
OK
A rock hit my Windshield on the Highway 12 days after I bought it. The chip was unrepairable and spread about 4 inches after a day. I actually had tinted the one that cracked.
I've put the Aeroskin 2 deflector on since to help avoid rocks in the future.
