Towing package for better acceleration
Gpp
Gil
Sanford nc
2022 ford maverick
does the mavericks with ecoboost and towing package run much faster in 1/4 mile than one without it.thinking about giving my daughter mine and getting a new one.or even 0 to about 75 maybe.only getting the towing for a little more get up and go😎
notfast
Los Angeles CA
I think it'd come more to driver skill and reaction time and that any difference on a Maverick with a towing package versus without would be negligible at best. Hell maybe with the towing package would be worse since the vehicle has more static weight.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
I've heard the AWD hybrid is the quickest but could be wrong so if you're going for speed then maybe look at that w/ the tow pkg
The AWD EB is about 2-3 tenths quicker 0-60 than the AWD Hybrid. The tow package for the EB has a lower gear ratio, in theory it should be slower than without it.
craigt502
WI
youtube.com
23 Maverick Lariat
Should be faster acceleration with the lower gear ratio. And faster 1/4 mile times.
Several years back I would go to the 1/4 mile drag track and run my modified 1998 Buick Regal. 12.7 was my PB.
Ford Maverick Towing package for better acceleration IMG_7084
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
IIRC the 2025 AWD Mavericks with the 2.0 EB's have the same 3.81 axle ratio[ even without the tow package] as the older AWD Mavericks with the 2.0 EB and the tow package have.
BLUEOVALRACER
Ravenna,Ohio
Supercharged V-6?
Hunters Edge
Sid
F150 crew
No I think the EB AWD is 5.9 vs 6.7 on the hybrid AWD from 0 to 60.
Hunters Edge
Sid
F150 crew
More than that I think the EB AWD is 5.9 and the hybrid AWD is 6.7 from 0 to 60. If the OP is looking for more get up and go the EB is the option but may use more fuel depending on city, highway or combined driving or the heavy foot the driver has.
I do agree on the gear ratio on older models not sure if the gear ratio is still different with the optional Tow Package. I didn't see it on the 25 and didn't look on the 26 model. The lower gear ratio may hurt in the long range but helps taking off in the hole. So possible may be what you described in your post.
I will add that my 24 with the optional gear ratio you can visibly see the difference in estimated fuel economy between 60, 70, 75 and 80. The sweet spot is 50 to 60 mph. 70 can be noticable if hills but 75 and 80 it's going down.
Gpp
Gil
Sanford nc
2022 ford maverick
Kinda sounds like not a whole lot of difference ane way or the other.the v6 would be great but we know that isn’t happening.maybe my daughter wll bring my truck back soner or later😎
Joshoc88
Josh
NY
25 maverick xlt 2.0eb azure gray
Why do we need a v6 when the transmission can't handle a 2 liter 4 cylinder? The motor makes more than enough power to break stuff, the trans needs the upgrade, not the motor.
Howard
Howard
Indiana
24 Atlas Blue, 2015 Escape
Yes, the tow package at one time came with a lower gear ratio, but it is somewhat overated here. It was not enough different to be really significant. 3.81:1 vs. 3.63:1 is a 5% difference. In most cases, when a manufacturer offers an optional ratio, it is usually a 10-15% difference in ratio. 5% does make a difference, but not one that you're likely to notice.
Rileyotta
Riley
Edmonton
I swear I felt my 2023 EB without the tow pkg had more acceleration off the line than my 2025 EB with tow pkg.
