Towing - Loose hitch in receiver on 4k tow package.
notfast
Los Angeles CA
Late replies but...
Plumbing repair tape is pretty stretchy and works better than electrical tape.
Also the plumbing repair tape doesn't get gooey after a few heat cycles.
It's not a good idea to use a weight distribution hitch on a unibody vehicle like the Maverick.
https://www.etrailer.com/question-241876.html
I guess I'm pretty conservative with towing, but I'd go one further and say that, if you need a weight distributing hitch, you should probably get a different tow vehicle or a smaller trailer. WDH's are giant levers that put a ton of stress on the trailer tongue and the vehicle hitch.
Even with my F-250, I towed a 7K trailer with a standard weight-carrying hitch most of the time. I got a cheap weight-distributing hitch as a supplement but it towed fine without it. I'd tow weight-carrying if it was windy or if I knew the freeway was very washboardy. The constant up-and-down is a great way to break a trailer tongue. Wasn't too concerned about the hitch since that thing was like...3/8" plate and 1/4" wall tube held on with 8 bolts. The trailer tongue was like 2x6x.125 wall tube.
Packer Bill
South Dakota
I've used this type of anti rattle; it removed all hitch movement.
I also purchased this and it worked as advertised!
