Tires problem, just realized today. 6/30
Warren's rvw
Warren
Sierra Vista AZ
2024 Maverick
Normal, although it doesn't look it...
Watch to make sure that the tires are blowed out on the rims all the way . There is a little bead by the rim that should be the same all the way around the rim. I had a F150 with Goodyears on it that we tried to balance 4 times till a tire technician caught that all 4 tires were not blown out on the rims right.
Toddman45
St. Louis, MO
No balance issues, just the dimple from the manufacturing process.
Ford Maverick Tires problem, just realized today. 6/30 17198732982865603832908180146700
Oscarcat
Eric
Encinitas California
I picked up the truck last Tuesday, it not an even a week old. I see on. My tire, it feel out of balance, do 70 to 80 on the interstate…
It on all 4 of them,
I am going to the ford dealership in the morning
My tire pressure was 45 psi when I picked it up. As others have said, adjust your pressure. Do it first thing in the morning before you have driven it and before the sun beats down on the black rubber, heating it up and increasing TP with it. 35psi cold.
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
FIY about the appearance:
SSM 51381 2021-2023 Various Vehicles - Tire Sidewall Wavy/Indentation Appearance
Some 2021-2023 Ford and Lincoln vehicles may experience a tire sidewall wavy/indentation appearance in the radial direction on one or both sidewalls. Sidewall wavy/indentation appearance is a common cosmetic characteristic of radial tire construction and will not affect the performance of the tire.
Mine look the same as yours.
