Thread Size of Positive Terminal on Hybrid
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
Confirming that a 5/16 x 18 nut does in fact work on the under the hood positive terminal on a 2025.
CrashedMaverick
Jack
Crashed Maverick
How about the nut to the left of the positive terminal? The DC to DC converter that has the little jumper cable crossed out. Also 5/16 x18?
BlueSpec1
Gene
M8 x 1.25 on a used 300A fuse assy I have.
It's the front stud, missing the flip cover.
Ford Maverick Thread Size of Positive Terminal on Hybrid 1758844296918-va
CrashedMaverick
Jack
Crashed Maverick
Front stud? Are you showing the one that I pointed out?
Are the two studs in direct continuity with each other?
BlueSpec1
Gene
Front stud? Are you sending one that I pointed out?
Separate. Both bolt to bus bar. Fuse under the front stud.
Ford Maverick Thread Size of Positive Terminal on Hybrid 1758868556641-ty
chiko
Eric
Hampton, VA
2024 Maverick
I am also trying to do a charging solution for my MY24. I will try 5/16" SAE now thanks to this thread and Google.
I will confirm that the post under the black cover is M8 (pretty sure it was 1.25 thread) and that the nut under the black cover is pretty close but not close enough to the post under the red cover.
