Thoughts on 225/75r17
Rob.eberly19
Rob
Pa
Cactus grey maverick tremor
I love my ‘23 tremor and will be needing new tires in about a year. What do you think about 225/75r17 all terrain tires? How would they perform compared to tremor stock tires? Would they fit without modifications? Thanks for your opinions
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
I personally wouldn't. I vaguely remember looking into that size and they seemed very heavy given their dimensions.
I'd stick to the 235/65/17 and then upsize to 245/65/17 when the stock tires wear out.
Or sell the stock tires and upsize to 245/65/17 if you feel the larger tire look is worth it to you.
Cancunbadlands
Cancun
Cancun
235/70R17 is a better option.
You might need to cut the welding edge off to fit the /75's
225/75r17 will rub for sure, even with a 1.5-2" extra lift over the factory Tremor 1" lift
Cancunbadlands
Cancun
Cancun
That's correct, 245/65R17 is the smartest size to choose from
hdave
Toronto, Canada
this is true too. If you search 235/70/17 maverick here or youtube, you'll see a video.
I personally run that size on my hybrid because I got a great deal on that size.
They should be fairly similar to the tried tested and true 245/65/17 and performance should be about the same with little to no noticeable differences.
245/65/17 is probably going to be your best bet still because you'll find a better variety of tires, and likely better prices.
Robot-Wrangler
Kentucky
235/75R17 Hankook AT2
Ford Maverick Thoughts on 225/75r17 20250119_140959
Escapologist
Niagara Region, ON
Got a friend of a friend offering me 235/70R16s on steelies, snows about a third worn. The meats will fit in the pie hole I assume, it's just the caliper clearance might be slim to none... thinking I might pick them up and test fit and if a finger gets under the pinch point, test drive them.
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
Maybe an inch taller is all I'd go in order to not have rubbing issues "offroad" (off pavement). That gives a half inch more ground clearance. I'd also go skinnier for better mpg and better traction (I don't drive on sand or mud where large contact patch might be beneficial; smaller contact patch has better traction on dry and rocky surfaces).
Kpankow
Kirt
Vail, AZ 85641, USA
2025 Maverick Tremor
Keep in mind, the tire diameter changes depending on the Width (225) and the Aspect Ratio (75). Here's a screen shot of a simple spreadsheet I made to calculate different tire sizes.
Ford Maverick Thoughts on 225/75r17 Tire Diameter
Good Luck.
