Thermal R&D - LOBO Review
PepeXL
Coop
Oklahoma City
2025 Maverick Lobo 402A
Finally got the time for putting the exhaust on the Lobo. Made for a good father's day project with dad. The quick version, im in LOVE. The truck finally sounds like it looks (at least in my head).
Shipping was quick, and service even reached out to me to ensure I did not have a GPF on my model Lobo. My only minor complaint was some buildup from factory in the pipes. Everything else was 10/10 on the Thermal R&D production side.
I've installed a number of exhaust over the years, this one was the easiest/fastest ever (only took 1 beer, and the 2nd beer to admire the work) . Easily taken off from Ford, even easier install from Thermal. Slapped it on piece by piece, adjusted angles, and tightened it up. DONE
Sound is perfect for me. Daily drive it for work, and typically run in LOBO mode. Its loud when it needs to be, and reasonable at idle/cruising. If you want to hear it, punch it. Need to take a phone call, just cruise and you hear fine. No drone, no overdoing it.
Fully back this exhaust system. Hard to shop around when you can only listen to videos. That said, video files are too large. Ill find a way to post them here for sample
Ford Maverick Thermal R&D - LOBO Review 20260620_155108
Ford Maverick Thermal R&D - LOBO Review 20260620_155021
Cancunbadlands
Cancun
Cancun
Try to record 15 seconds tops
Here's my Borla Pro XS
Cycopath
Tucker
FL
2026 Maverick hybrid AWD
I installed a Thermal exhaust on a customer's Explorer ST, thought it looked good and had a good sound. Definitely an easy install, too.
scott1070
Scott
calgary
25 lariat
It looks like you’re sacrificing some ground clearance with that setup. That’s a hard no for me.
Tbone289
I agree. The turn-down version is better as far as interfering with departure angle, but I don't like how much lower it seems under the RDU. I might consider the one that exits in front of the rear tire though.
EDIT: I was thinking thermal had one with that configuration, but now I don't see it. Maybe I'm confusing Thermal with another vendor?
PepeXL
PepeXL
Coop
Oklahoma City
You're going to hate it when i get the lowering springs installed on it too lol
PepeXL
PepeXL
Coop
Oklahoma City
Seen it mentioned so ill address it. The exhaust kit does lower your clearance around 1" (unconfirmed/eyeball measurments)
PepeXL
PepeXL
Coop
Oklahoma City
Tried that. Only way I can make it work is on the lowest possible camera setting for less that 10 sec. But screws up the audio. Ill figure it out eventually lol
scott1070
Scott
calgary
25 lariat
Nope. I don’t care what you do with your own vehicle. You must have poor reading comprehension if you think I would somehow care.
