Text Message Playback Voice
Ozarkbeard
... have you tested getting RCS messages on the basic infotainment system?
No, I haven't. I don't talk or text at all while driving.
Does the problem happen when you're using Android Auto or just Bluetooth connection to the truck?
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
Bluetooth; I never bother with Android Auto. I thought AA was going to be lots more useful than it really is for me. I use a Garmin GPS for nav, mostly because I want it to work without cellular data. If an SMS msg comes in while I'm driving, I can poke a virtual button and have it spoken. RCS messages are invisible thru the truck's UI. I should research this more myself. The answer is out there somewhere...
Ozarkbeard
..I use a Garmin GPS for nav, mostly because I want it to work without cellular data...
You can download all the maps you want in the Google maps app and use it without an internet connection. All you need is GPS.
No traffic data, of course.
Jeff D.
Jeff
Duluth, MN.
MetalsGeek, one thing I do is have it set so Android Auto connects, but does not open. My Sync 3 radio stays as my default screen. If I do get a phone call, or text, AA will then open. Also, if I press the voice command button.
Otherwise, the only way I know AA is connected is the option appears on the bottom row.
Just a thought if you haven't tried that. Maybe a tolerable work around for your needs?
MetalsGeek
Rough
Torrance, CA 90503
MetalsGeek, one thing I do is have it set so Android Auto connects, but does not open. My Sync 3 radio stays as my default screen. If I do get a phone call, or text, AA will then open. Also, if I press the voice command button. Otherwise, the only way I know AA is connected is the option appears on the bottom row. Just a thought if you haven't tried that. Maybe a tolerable work around for your needs?
Thanks for the suggestion, although my XLT does not have SYNC3. I find that physically connecting my phone every time I jump in the truck to run a quick errand (to use AA) is simply too much hassle for what it's worth.
Jeff D.
Jeff
Duluth, MN.
Yup, understood. Without a wireless dongle, that monkeying with the cable every trip would stink. (y)
For the OP's original question, today I tested changing the voice in Google Assistant, and it does change the voice that reads the texts. So, if they're using AA, that option does work.
nospam56
nospam56
PF
ny
'25 Eruption Green, the '24 was held hostage by the camera
PF, are you using Android or an I-Phone? If Android, you could try changng the voice of Google Assistant to see if that would change the voice that reads your texts.
On my phone I go to setting > Google Service and Preferences > All Services > Search Assistant and Voice > Google Assistant > Assistant Voice & Sound" > Assistant Voice.
They label the voices as colors, but each is a different voice. I think "Red" is the default female voice. Blue is a male voice. Lots of different options.
I'm not sure this will change the voice that reads your texts, but it's possible as Android Auto uses Assistant.
If you use an I-Phone, I can't help.
Good luck! :)
The default is horrible. I already chose another color and will give that a try. thx
MilleGrs
Michelle
United States
2024 Ford Maverick
Had the same annoyance with my car—voice reading texts just sounded off. Ended up switching some important messages to a service like bulk sms so I could hear them clearly on my phone instead. Much easier to follow a grocery list or quick reminders without the car’s voice getting in the way.
