- Jun 20, 2021
- United States (TN)
- 22 Maverick XLT Iconic Silver
- Engine
- 2.5L Hybrid
I went looking for the mount points BootXL76 mentioned when he mounted his LC2i Pro behind the glovebox. I think I found the location and I decided to measure and mock up a foamboard replica of the Key 200.4 in order to get everything to fit just right. Some of you may be able to work out of your head and just eyeball and and craft something elegant up, but I have to put some effort in to it, otherwise I would have a rattling box in my dash and my glovebox wouldn't close.
I took some measurements, held the foam "Key" up and starting drawing some parts and fitting, modifying, and revising. Took about three tries on the bracket mockup:
1. Several revisions and changes
2. Foamboard mock-ups of bracket and Key 200.4
3. Foamboard bracket fit to existing bolts
4. Kicker Key 200.4 mockup pinned to bracket and glovebox door test fit for clearance
5. Once satisfied with the fit, I cut a template from MDF and pattern-routed 1/8" ABS
6. Clamped straight-edges top and bottom and heated ABS, bending it at a right-angle.
7. Bracket is a great fit for the Kicker Key 200.4
8. Bracket also will accommodate the AudioControl LC2i Pro
Attached is a .PDF for the flat-pattern template for the bracket. It can be printed (make sure PDF is printed actual size and not scaled to fit) and adhered directly to ABS and cut or used to make a template.
9. If printing full-scale template, ensure Actual Size is selected.
ABS edges are smoother if routed, but sawing is fine as this bracket will likely not be visible much.
I hope this saves someone some time. I certainly appreciate all of the advice and ideas I got from those of you that trail-blazed the audio on this vehicle.
