Temperature sensor issue with S&B cold air intake
Jdodson
Denison texas
2024 ford maverick
After having a local installer put my S&B cold air intake on I got a check engine light for the temperature sensor. The installer did everything he could to get the S&B extension that came with the intake kit to “Click” properly on the sensor but it was happening.
When I called S&B they shipped a new one to me overnight free of charge. It should be here sometime today or Monday.
Has anyone else had the same issue?
Franklin
Frank
Cleveland Ohio
Yes - same thing happened to me- in my case they disconnected the battery for 2 hours and then reconnected it- problem solved
Jdodson
Denison texas
2024 ford maverick
I’ll have to try that. Thank you.
Jdodson
Denison texas
2024 ford maverick
Disconnected for two hours did not fix it.
Jdodson
Denison texas
2024 ford maverick
Going to try getting the code cleared then retry the two hour battery disconnect next.
Superg0
2024 XLT FX4 Azure Gray
I have the S&B and installed it myself. I disconnected the battery and did not throw a code. It was disconnected way more than 2 hrs......lol...that pipe connected to the turbo is a PITA
Jdodson
Denison texas
2024 ford maverick
I do not think the installer disconnected the battery first. The check engine light came on as I was driving away. I left the battery unplugged for about 2 hours and twenty minutes today. When I hooked it back up the engine light was still on.
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
At 4:08 of the above video he disconnect an electrical connector that I almost forgot about. Just by chance maybe the installer forgot it also.
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
OMG, that turbo pipe was a beeeotch!
Jdodson
Denison texas
2024 ford maverick
It was the S&B extension that came withe intake. Plugged in the new one and the problem was solved.
Superg0
You got a new one or the installer never used it?
Jdodson
Denison texas
2024 ford maverick
I got on the phone with S&B and the next day aired me a new one for free.
Marjammer
Jack
Beavercreek, Ohio
'23 Atlas Blue Lariat Tremor
Do you mean the rubber piece that connects the IAT to the intake just downstream of the filter?
wb5oxq
Waco Texas
2023 Maverick Lariat in Alto Blue
Must have the battery disconnected for a minimum of 2 hours. After changes to the exhaust system same thing if you want the computer to begin reading the new airflow instead of using the old readings which have changed.
