Tailgate won’t unlatch
t arnold
n ga
2025 lariet awd hybrid
Starting a different thread for this problem. 2350 miles and this am the tailgate won’t release. Worked fine till now. After taking 8 screws out of access panel immediately saw problem. There are 2 thin metal rods on a cam that when rotated (pull handle up) pull left and right to release locks on both sides. Lots of slop in operation. First notice that one rod had more threads exposed from the CHEAP plastic holder than the other. In my case the left rod was too long and wouldn’t pull enough to loosen the lock. So I unlatched did I say CHEAP HOLDER GRIPPING the rod (it is not thread, just pinched) and shortened it a few threads. Works for now.
Maverick Country Club
Larry
2025 Maverick Lariat Ruby Red Metallic Black Appearance Package
Thank you for sharing your findings, when/if it happens to me I will know what to do.
Ford Maverick Tailgate won’t unlatch IMG_7354
Bgolden
Robert
Iowa
2025 XL AWD Hybrid 1974 Chevy K20
Ford has a TSB for this issue
TECHNICAL SERVICE BULLETIN
Unable To Open The Tailgate From The Release Handle
25-2430
08 October 2025​
Model:
Ford
2022-2025 Maverick
Built On Or Before 12-Jul-2025
Markets: North American markets only
Issue: Some of the vehicles listed in the Model statement above may exhibit a condition where the tailgate is unable to open from the release handle. This may be due to damaged threads in one or both tailgate latch actuating rods.
Action: For vehicles that meet all of the criteria in the Issue and Model statements, follow the Service Procedure to replace the tailgate latch actuating rod(s).
Parts
Service Part NumberClaim QuantityPackage Order QuantityNumber in PackageDescription
NZ6Z-6043880-A​
1​
1​
1​
Right Tailgate Latch Actuating Rod
NZ6Z-6043881-A​
1​
1​
1​
Left Tailgate Latch Actuating Rod
Service part numbers and "number in package" quantity may change after publication, thus also affecting the "package order quantity". Refer to the parts catalog for the latest information.
Claim Quantity refers to the total number of individual pieces required to repair the vehicle.
Package Order Quantity refers to the amount of the service part number package(s) required to repair the vehicle, also known as unit of issue (UOI).
Number In Package refers to the number of individual pieces included in a service part number package.
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Service Part New Vehicle (SPNV)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SPNV/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2022-2025 Maverick: Disconnect And Inspect Tailgate Latch Actuating Rods (Pass) This Article Does Not Apply
252430A​
0.3 Hrs.​
2022-2025 Maverick: Disconnect And Inspect Tailgate Latch Actuating Rods (Fail) Replace One Or Both Tailgate Latch Actuating Rod(s)
252430B​
0.4 Hrs.​
Repair/Claim Coding
Causal Part:6043880
Condition Code:C2
Service Procedure
1. Disconnect both tailgate latch actuating rods from the tailgate latch control assembly. Refer to the WSM, Section 501-14 Handles, Locks, Latches and Entry Systems > Removal and Installation > Tailgate Latch. (Figures 1-2)
Figure 1
Figure 2
2. Inspect both tailgate latch actuating rods for damaged threads as shown in Figure 3. Do the tailgate latch actuating rods exhibit damaged threads?
Figure 3
(1). Yes - remove and discard the affected tailgate latch actuating rod(s). Refer to the WSM, Section 501-14 Handles, Locks, Latches and Entry Systems > Removal and Installation > Tailgate Latch. Proceed to Step 3.
(2). No - this article does not apply, perform normal diagnostics outside of this article. Refer to the WSM, Section 501-14 > Handles, Locks, Latches and Entry Systems > Diagnosis and Testing > Pinpoint test AB.
3. Install new tailgate latch actuating rod(s). Refer to the WSM, Section 501-14 Handles, Locks, Latches and Entry Systems > Removal and Installation > Tailgate Latch.
4. To assemble the vehicle, reverse the removal procedure.
© 2025 Ford Motor Company
First Sergeant
Fruitland Idaho
25-2430
08 October 2025​
Model:
Ford
2022-2025 Maverick
Parts
NZ6Z-6043880-A​
1​
1​
1​
NZ6Z-6043881-A​
1​
1​
1​
Labor Times
252430A​
0.3 Hrs.​
252430B​
0.4 Hrs.​
Repair/Claim Coding
Causal Part:6043880
Condition Code:C2
Service Procedure
Figure 1
Figure 2
Figure 3
Rather than purchase a new rod, I would first try a proper sized die to "clean up" the threads, then use a lock nut or regular nut with some thread locker to keep it from moving in the future. Save a few bucks and the time to go to Ford dealer 35 miles away! Edit: Forgot about the Ford guy across the river here, (mostly a farm/truck type dealer) only about 5 miles.
Bob Hamilton
Vancouver, Canada
2025 Maverick Lariat Hybrid
Gotta admit, that CHEAP HOLDER GRIPPING the rod REALLY DOES LOOK CHEAP! C'mon, Ford -is this really the best you could do?!?!
It is not the best Ford could do.
It was the cheapest Ford could get and still work, most of the time.🙄
