Sync3 upadate Lariat lux
NJBob
NJBob
New Jersey
It's not hard using the usb stick if you know how to move files and extract them. Took 20 minutes once the stick was prepared. Interesting what you said about the Lariat. Why even have wifi then? It don't even fail just says your up to date when it's not. I am just used to when getting new tech it always has updates. Only issue I have is sometimes the center display does not propery display the correct song while the touch screen does. Not sure if it would fix that.
bighap
Oregon
2023 Maverick Lariat Hybrid
From 23 on there is no WiFi. How does this get updated without WiFi?
No. Wi-Fi hotspot was removed. Not the same thing.
jeepgrady
Lehighton, Pa.
2021 Jeep Grand Cherokee L. 2022 Lincoln Corsair
The update will not correct your display issue. I have the same issue. My 22 Lincoln Corsair which I've had for almost 2 years has the same glitch.
NJBob
NJBob
New Jersey
Thanks did not think it would. Only issue I've had with the Mav. Small issue
CalCWORet
2023 Ford Maverick Lariat Luxury w/CP360 & CP360A
robbyrob
usa
acar
I have tried everything
I have tried everything new USB flash drive
CANNOT PLAY MP3'S FROM ANY FLASH DRIVE
Made sure the USB drive was FAT32 deleted my phone added it back on did all the updates still Ford carplay or whatever it is never sees my USB What a waste I moved on
that is not at all what this topic is discussing.
robbyrob
usa
acar
sling your arrows at thee
dummy me the Usb port DOES NOT WORK now it wont even charge let alone recognize a phone
so the usb insert mechanism is kaput
what to do? warranty?
ty
Joe Mac
Marin
Shelby GT350 F250 Super Duty
I bought the update from Ford. It was 40 dollars and it works great. Just plug it in and it takes about 45 min.
I have spotty wifi so this is the easiest to way to update
robbyrob
usa
acar
ty
bgn
WA
ty
If it's not at least charging, then something is definitely wrong. Take it to the dealer.
Yes. It's not very widespread, but definitely some trucks have had bad USB ports. Actually pretty sure it's across the board of Ford models. Some fail.
OXHB619
Clayton
XL EB 2.0
ty
try a hard reset of the stereo, that fixed a similar issue for me. I think it’s holding power button plus fast forward/seek for ~5 seconds
jcast0311
South Texas
2023 Ford Maverick Lariat 2.0 EB LUX FX4 4K CG
Well looks like the usb method worked. Went from version 21194to 23188. Shame the auto update did not work. Maybe this will fix that.
Audio update?
ripperAZ
AZ
2022 Mustang MachE 2021 Genesis G90 2032 Mav
Since I have had my 22 Lariat Lux I have never has an update on the sync 3. I am confused as to what version I have as it does not match the versions even remotely from what others have posted. If anyone can explain this I'd be grateful. See attached photo. Thanks
I wasn’t able to get any Wi-Fi updates until I installed the new sync version from the USB that I downloaded from the Ford support site after that the Wi-Fi loaded map updates and other stuff. Hope that’s helpful. Maybe try the USB port for your first time sync update.
https://www.ford.com/support/how-tos/sync/sync-updates/how-do-i-check-for-sync-updates/
