Sway Bars on a Maverick Tremor?
PRW
Rob
Western Connecticut
2024 Maverick Lariat Tremor
Does anyone know if you can (and should or shouldn’t) add sway bars to the suspension on a Maverick Tremor?
Looking under the truck, I don’t see anything that looks like a traditional sway bar, and I wonder if that’s because it would limit suspension travel too much for the off-roading capabilities this truck is designed for.
the reason I ask is that the truck tends to wallow quite a bit at higher speeds on curvy roads. I know it’s no sports car, and that the suspension is optimized for rough terrain at slower speeds, but just wondering if I have any options to tighten things up…or if that’s a bad idea even if it is possible.
Yeah, I know that I should probably have just gotten a Maverick without the Tremor package with most of my driving being on highways…but the lifted truck with the off-road tires just looks so much better than the other models. And I do have a lot of poorly maintained dirt roads near my house, and wanted to be sure I got a truck that was comfortable in those conditions too.
I do love the truck, and won’t be disappointed if I just need to get used to the squishy handling in the curves (and just drive my Focus ST when I want to be happier on fast, curvy roads).
Ford Maverick Sway Bars on a Maverick Tremor? IMG_2508
Bwicka
Lakeside,ca.
Front sway bar is parallel to steering rack and is somewhat stiff for the tremor . With my mods I have mine disconnected now , does wallow a little on a hard corner exit under power , but some of that is the torque steer from the front wheel drive .
Ford Maverick Sway Bars on a Maverick Tremor? IMG_3441
Get a lot more droop now and put the spring and shock to work doing exactly what they are to do without added resistance of sway bar tension in either direction.
SubtlySeismic
Don
Houston, TX
2024 Maverick XLT Tremor
I was wondering this same question. It's not like the trucks come with a tremendous amount of ground clearance. They will never be a rock crawler, so not sure it makes sense to worry too much about suspension travel. Stiffening up the suspension with a thicker rear sway bar will definitely take away from the offroad abilities. I just don't know how much. I would be nice to know if anyone has tried an anti-sway bar on their tremor.
