Sub install?
PMAG538
Peter
New Jersey
2024 XLT Tremor
i wanna install a sub in my maverick. I know there’s a lot of posts on this already but whatever. I wanna know what I need to buy to make this work i already have all new speakers so the only think left is the sub. Most importantly what connector do I need. I see a lot of people get the pluginplay kits one. will that work with any Amp? Sorry in advance I’m kinda an audio noob. Any info helps thanks!
AF Blue
US
NA
Welcome to MTC!!!
I used: PAC LPHFD31 LocPro Advanced T-Harness
I used high level inputs to amps (Kicker Key)
wax87
Stuart
Dallas South
2004 Avalon
Welcome to MTC!!!
1st question to answer, a powered sub (easy) or a sub with a separate amp (complex and varried)
PMAG538
PMAG538
Peter
New Jersey
2024 XLT Tremor
I guess im looking to do a sub with a separate amp I’m looking for quality and I’m cool with doing some diy!
Aaron F
Aaron
Sterling Heights, MI
2023 Maverick Lariat Lux w/ 4k and BAP / 2025 Maverick AWD Hybrid Lariat w/ 4k
A Plug n Play kit or the Pac T harness above should work to give you high level inputs to an amplifier. You might want to install your upgrade speakers first and see how they sound. The reason I suggest this, is it will be easier to decide if you are happy with the upgrade, or if you want to amplify them along with the sub. Then, if you want to do a 5 channel vs 2 separate amps, you won't end up buying twice or trying to figure out how/where to mount a 2nd amp
PMAG538
PMAG538
Peter
New Jersey
2024 XLT Tremor
I already have the upgraded speakers installed. I don’t mind how they sound. with the harness for the amp do I have to wire the speakers into the amp or sense it’s hooked into the harness it just connects the speakers that way? Also what amp would you recommend? Sorry once again I’m somewhat new to audio
Aaron F
Aaron
The T harness is basically an OEM fit harness splitter to tap into your speaker inputs. It feeds a high level input signal to an amplifier since you will not have RCA outputs to use on the factory radio. It does not run like an output from your amplifier to your speakers.
Have you decided on a sub/box setup yet? That really helps determine what amplifier to choose based on how much power you need at what ohm load. I am running 2 Hertz MPS250s wired at 1ohm on a D'amore 1500.1 for the subs.
Toddman45
Todd
St. Louis, MO
I would definitely opt for a 10" sub, build or buy a box for one of your rear underseat storage areas, and put the amp behind the seat.
PMAG538
PMAG538
Peter
New Jersey
2024 XLT Tremor
O okay that clarifies a lot thanks. I was thinking about doing a 10 inch sub. Not sure what brand yet but I’m gonna build the box myself.
PMAG538
PMAG538
Peter
New Jersey
2024 XLT Tremor
I would definitely opt for a 10" sub, build or buy a box for one of your underwear storage areas, and put the amp behind the seat.
Yeah that’s exactly what I was thinking about doing the hard part is just figuring out wiring. electrical isn’t much of a strong suit for me lol
Montana
Me too!
But I'm too lazy to do it.
Got down to do my oil the other day, was going to rotate tires and flush the transmission... but the nope kicked in.
Maybe if I had gotten a non Lariat I'd already have a sub installed, but the 6x9 handles Skrillex pretty well...
Ford Maverick Sub install? dubstep-faces
