Streering Wheel Not Centered
matt123
GA
2024 Maverick
I am hoping to get some insight as to my next steps. I have taken my truck in twice to my local dealership to get the steering wheel straightened. They have done an alignment both times, and this last time my wheel was even more crooked than before. I understand how you straighten a wheel with a normal steering system,. but is there something harder on a Maverick? They are blaming the drive by wire system,and I want to know if it is really that hard or is I just have a inept dealership?
Seems like it shoudl be an easy fix, but maybe it really is more difficult on a Maverick? Thanks for any thoughts.
Ford Motor Company
Official Ford Account
Dearborn, mi
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Yeah, should be able to center the wheels, pull the wheel off and put it back on centered. BTW the ford account sends that same "we care about you" but seems they don't accomplish much
matt123
GA
2024 Maverick
I am sure. I had a different issue with this dealership and corporate Ford could not even get someone on the phone. I feel like dealerships can kind fo do what they want and it is on you to find a good one since they don't seem to have a ton of accountability to Ford.
I mainly wanted to know if they are just making up nonsense to cover their tails which is what it sounds like to me. Just stinks because the dealership is about 3 miles form my house and the next one is about 20.
Tbone289
You don't have to pull a steering wheel off to center it. You only have to set the toe angle of the front wheels correctly.
EPAS (Electric Power Assisted Steering) is not drive-by-wire, as stated above. Clearly your dealership doesn't know what they're doing. Take it somewhere else.
PNWMaverick
Pacific Northwest
2022 Maverick Hybrid - RIP
A few possibilities:
  • It could be that the steering wheel is simply mounted off center and needs to be taken off and centered.
  • It could be that the steering angle sensor needs to be reset. Allowing the wheel to be put back on center so they can do a proper alignment.
  • It could be horrible alignment and you might want to go to an independent shop to have it looked at.
I sent you a PM.
That is a bot account that won't help you.
Tbone289
The steering shaft is hexagonal where the steering wheel bolts on, so there are only 6 possibilities, 60 degrees apart. There's not much chance it was mounted 60 degrees off center at the factory.
matt123
GA
2024 Maverick
That is what I thought. It is my understanding that you lock the steering wheel center (and maybe reset the sensor) and then redo toe. I do appreciate the insight into the drive by wire part. My Maverick is new so I have not really looked up under it much yet.
I will schedule something at another dealership.
fltwd
Jeffrey
Paragould, AR
2025 Maverick XLT
This will sound meaner than intended, but are you heavy? I only ask because that can affect steering geometry. At one time, I weighed 350lb, luckily not anymore. Anyways, I had a ram truck that the steering wheel was never straight on. The alignment guy politely asked me to sit in the truck the final time and he aligned the truck with me in it. Never had a problem with that truck ever again.
