Steering Column ergonomics?
  • Thread starter Deleted member 6544
  • Start date
  • Watchers 0
Deleted member 6544
Guest
I did a search and didn't find anything. Any comments from current Maverick drivers as to the telescopic steering column? I myself, although only six foot tall am all legs with a 34 inch inseam. The ergonomics of modern SUVs with their short stubby noses leaves my legs scrunched up while my arms are damn near straight at the elbows. I love the telescopic steering column in the Corvette. I can have my legs extended and arms bent with comfort. I am looking forward to it in the Maverick.
thunaman
Andy
Peoria AZ
2017 Subaru Outback
it has a telescopic steering column. are you looking for more specifics?
Deleted member 6544
Guest
Yes I knew it did. I was just wondering how folks like it, and or if they even use it. Back in the day lots of cars had them but then seemed to go out of fashion, (or lost for cost reduction).
Crowley Cajun
Crowley La
Nissan Titan
I test drove an XLT. I’m 6’4” and the telescopic wheel was great. I also have 34” inseam and was able to get very comfortable adjustment with the steering wheel. Only a 10 minute drive but no problem for me for that short time.
oldfatguy
tom
1997ranger 2006 fusion 2001 bmw330ci 2004.5w3500
i'm 6 ft and my wife is 5'8" and we are able to not move anything at all and we are both good with it , i have moved the column around and thought there is plenty of adjustment
Deleted member 6544
Guest
That's great and thanks for the reply. I'm really looking forward to driving a vehicle dailey that will be comfortable.
Deleted member 6544
Guest
Awesome and good for you. Thanks for the reply. I won't be getting mine til probably May, birthday present?!!
WannaMav
Hawaii
2022 Maverick hybrid
You ought to be just fine.
Consider the adjustable column a benefit of...
...trickle down ergonomics.
Deleted member 6544
Guest
Unfortunately I'm old enough to get it, and great play on words!
Deleted member 6544
Guest
The steering wheel functions just fine ergonomically, but I find it a bit chunkier than it needs to be. It definitely obscures some dash stuff. I have to move my head far to the left to be able to see the lighting controls for instance. I also wish that one of the 10 screen options would be a giant number in the middle with my current speed...
Interesting, I'll look for that. Thanks for the honest response.
uh50
Howard
www.hchaney.com
2022 Maverick XL, VB, 2.0 EB
I'm short at 5' 7" and the adjustments are more than I need. I suspect that the telescopic and up/down adjustable range will fit many.
rlhdweman
Random Lake Wisconsin
Many vehicles with telescopic steering column lost that option when air bags arrived. It will be nice to have that option back again.
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
2022 Ford Maverick Lariat
I'm 6'-1" and 370 lbs. I had no problem telescoping and raising the Maverick steering wheel into a good position. Exactly the same fit as my full size Lincoln Mark LT when it comes to distance from steering wheel to body, above my lap and in front of my gut. That's with the seat all the way back, of course.
It's probably helps I have long arms. If someone had my girth and short arms and needed to sit closer to the steering wheel, it might not work out as well.
The biggest issue regarding the Maverick for me is the tall door sill. With my long legs and big feet, I have to pull back my feet to clear the door, while raising them over the sill. Much easier to do on a flat floor out the door. Not a big deal if I can fully extend out the door. But if someone is parked too close, it can be quite a maneuver to have to tuck, raise and twist my big feet back out behind me in the reduced door opening. But doable. I will just park further out in most situations to prevent the problem.
oldfatguy
tom
i dont know about the fx4 but on my xlt you can get a speed only on the center display
