Mitch Panda Motorworks
Diamond Sponsor
Mitch
St. Louis, MO
22 Maverick XLT, 2021 Bronco OBX, 2015 Focus ST
Improve your Maverick's Performance with the Stainless Works Downpipe! Get yours today from Panda Motorworks!
Ford Maverick Stainless Works Downpipe for Maverick Now Available at Panda Motorworks! MAVSWDP (1)
Why Choose The Stainless Works Downpipe?
It uses the highest quality materials and construction. This downpipe is designed to fit your vehicle perfectly and provide years of trouble-free performance. It is also backed by a lifetime warranty, so you can be sure that your investment is protected.
The EPA-Compliant high flow catalytic converter is made from high-quality materials and is designed to flow more exhaust gas than the stock catalytic converter. Stainless Works tested this downpipe and saw gains of 31 Horse Power & 41 Ft. Lbs of Torque. We will update this with our numbers once installed and tested on our DynoJet Dyno. When tested on a stock truck, no check engine light appeared.
The American Made Downpipe is constructed using 3" mandrel bent 304 stainless steel tubing as it is durable and corrosion-resistant. It is also mandrel bent, which ensures a smooth and consistent flow of exhaust gas. The downpipe is a bolt-on installation, which means that it can be installed without any welding. This makes installation easy and quick for a true bolt-on performance mod. Pair this with a Custom Tune from Panda Motorworks for the ultimate performance boost!
At the time of this post, the Stainless Works Downpipe is IN STOCK! So don't wait for a downpipe, when you can get one that is in stock today!
Diamond Sponsor
Mitch
St. Louis, MO
We've got these downpipes IN STOCK, so pick yours up TODAY! Also, Use Code "SW65" to save $65 on your Downpipe while supplies last. Orders placed today, ship today for FREE!
Buy HERE!
LSchicago
Lloyd
IL
31 HP with no tune on a completely stock truck?
Diamond Sponsor
Mitch
St. Louis, MO
Thats what they say. We will be updating it once we get one installed and tested on our dyno so we can either verify this or give real-world results.
LSchicago
Lloyd
IL
Do they make this for the Hybrid?
the downpipe feeds from the back of the turbocharger into the rest of the exhaust.
since a hybrid maverick doesn't have a turbocharger, it doesn't have a downpipe, either.
LSchicago
Lloyd
IL
Basically the same thing as a head pipe coming off of a manifold going to the cat (reversed in the Hybrids though). But not much in gains to be had on a non turbo hybrid exhaust.
a downpipe isn't the same as an exhaust manifold. both engines have exhaust manifolds but only one of them has a downpipe, because as I said it is only on turbocharged engines.
Maverickman74
Shane
Maui HI
Keep us posted on pure stock dyno numbers.
My jeep 4.0 straight six has a downpipe. It is sold and described as such. It just goes down from the manifold. These are technically turbo downpipes.
Either way
Ford Maverick Stainless Works Downpipe for Maverick Now Available at Panda Motorworks! oAwIFKWgHaE0?w=261&h=180&c=7&r=0&o=5&dpr=1.3&pid=1
Harry's Humble Hitch
¬Harry
the South East
Dakota, Maverick
burst710
fartman
las vegas
maverick 2022 ecoboost 2.0L
I love it , the pic with the hand is the (oem one)other pic is the SW installed
Ford Maverick Stainless Works Downpipe for Maverick Now Available at Panda Motorworks! 20240203_175527
Ford Maverick Stainless Works Downpipe for Maverick Now Available at Panda Motorworks! 20240203_210455
LSchicago
Lloyd
IL
Fully aware that both have manifolds. Never said one didn't. The hybrid manifold and cat are one piece. The head pipe bolts to the cat, doing basically the same job as a down pipe. No point in replacing this head pipe in the hybrid, as there would be no gains.
