Tire size/speedometer/MPG
ThrowbacK
Ricky
Corolla SE
I currently have the stock FX4 rims with the 225/65/17 scorpion tires. It is almost time for new tires and I wanted to get something alittle beefier looking. I don't want to add a lift to the truck or anything. So I am considering 235/65/17. I am able to get a good deal on that size for Falken Wildpeaks AT3w. I just don't want to mess up my mpg/speedometer terribly. I've looked across the forum and I have seen mixed answers regarding those issues. Anyone have any additional feedback?
I ultimately like the look of 245/70/17 but I think that would be too much for the truck and cause more issues regarding mpg/speedometer/lift.
Whatcolortochoose
Thomas
Hampton roads
2023 Royal Enfield INT, 2006 Honda Shadow 1100
235/65/r17 wildpeaks are standard on tremor and were an option for fx4's. The speedo can be calibrated to that size. Mpg impact is minimal. I just replaced my scorpian tires with firestone at2 in 235/65 r17 because they are comprable in performance but weigh less than the wildpeaks.
245 70 you may experience rubbing at full lock and expect mpg to drop 3-4
I think 235/70 is perfect for this truck if you want larger than stock size. Taller and narrower than the 245/65 most seem to be getting. But not very many options in 235/70.
ThrowbacK
ThrowbacK
Ricky
Corolla SE
Thank you for the response and info.
bgn
WA
Tire size calculator here will give you the difference between stock and whatever you want to change to: https://tiresize.com/calculator/
Speedo change calculator: https://tiresize.com/speedometer-calibration/
Tire size can be changed via Forscan, but I think it maxes out at 235/65R17 (the largest stock size).
For size, I recommend staying away from the 245/70R17 because they either run at lock or are very close to. I personally run 245/65R17 and wish I went narrower and taller with the 235/70R17.
ThrowbacK
ThrowbacK
Ricky
Corolla SE
What do you like about the 235/70/17? What benefit versus' 65?
bgn
WA
Taller sidewall tire, which would give me marginally more ground clearance off-road. Narrower, so potentially a bit less mpg hit, but that itself might be offset by the fact that it raises the truck a bit more compared to the 245/65R17s.
