Just replaced the front and rear speakers in my 25 XLT hybrid. Now the audio cuts out at high volume or when listening to a song with heavy bass. Do I need to get an amp or Forscan and mess with the eq?
Everything cuts at once. Really screws up my truck karaokeMy first thought, with the limited info we have, is to double check the physical connections. If volume or bass are the primary triggers, it could be vibration related.
Do all the channels cut out at once? If so, that means the problem is pretty early in the signal path.
The solution is, of course, MORE POWER! You will need to add an aftermarket amplifier for the speakers you replaced.Everything cuts at once.
